![]() Drives: 2007 Yaris Hatchback Join Date: May 2009
Help! Sway bar?
Hey everybody. So I've been looking at the site, and it looks like a sway bar is an upgrade I should probably invest in... I do have to ask, though, are there any downsides to doing it? Does it really matter if I get the 19mm or the 22mm thickness?
For the record, this is going to be the only modification I do... I really only drive to and from work and around town... Is this worth doing then? Any help would be greatly appreciated... |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Well being 22mm, the bar might make it a bit stiffer then a 19, but either one would do the trick and unless you really push the car to it's limits, you might not even tell the difference. Loren, what's your imput?
Who said Yaris was slow?
Why do you want the sway bar? What do you try to acomplish?
Do you feel like you car has too much body roll? Do you feel a lot of understeer on the curves? It all comes down to the way you are driving your car... If you haven't noticed the understeer and the body roll, then you won't feel a sway bar. The sway bar will reduce body roll and understeering... basically |
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
If you only want one upgrade and it's for handling you may want to consider lowering springs. I felt a huge difference both on cornering and at highway speeds (less turbulence), though I have a sedan. But good luck on whatever you do.
Tantum religio potuit suadere malorum. |
![]() ![]() Drives: yaris sedan Join Date: Oct 2008
i love the trd sway bar .. itīs a good investment
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, 21 Crosstrek Join Date: Oct 2008
A rear anti-sway bar would be an excellent lone upgrade.
Not only does it promote flatter cornering / reduced body lean but it greatly improved my sedans highway cross-wind manners. I've said it before, a rear swaybar should be on every Yaris, from the factory. It's that much better. And no downside. For the record: I installed the bar about a month prior to the TRD springs and shocks going in. I commute 500 kl / 300 miles a week with mixed city and highway running.
I think I remember Garm or Loren saying that switching from their 19mm to their 23mm made a huge difference.
Modded Moderator
Agreed that these cars should come with the sway bar. I had mine installed when I did my springs though, but wow, what a difference!
I went with TRD, wasn't much else out there at the time. If I had waited, I would have gotten the thicker one garm is selling. |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
I'd get the 22mm if I were you. If you haven't noticed any body roll or anything yet, you'll still feel a huge difference with one of these. And if you lowered the Yaris a bit (like with Tanabe NF210 springs), you'd feel even more of a difference.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
#10 | |
If you've been driving a SUV, van or something like that previously then bodyroll has been your way-of-life and the Yaris may not seem bad.
#11 | |
The larger bar is 23mm, not 22mm to be clear about that. And I agree that unless you are really pushing the car you would not feel the difference between the two. You will, however, feel the effects of putting a sway bar on your car, any sway bar -- especially since it doesn't come with one already on there.
![]() ![]() Drives: 2008 Yaris HB Join Date: May 2009
TRD sway bar from Sparks was my first and best mod so far. Transforms the car, that and putting 40 psi in the stock tires. Took all of 15 minutes to install, I didnt even jack the car up or remove the wheels, piece of cake. You will not regret spending the money.
![]() ![]() Drives: 09 3dr (sold), 12 SE 5spd : ) Join Date: May 2009
Are there any downsides to doing it? NO
Does it really matter if I get the 19mm or the 22mm thickness? NO Is this worth doing then? YES
Its all about the MPG's !! |
However, for the non-experience driver, a 23 mm rear sway bar shouldn't be a first mod, right (since it makes the car more oversteer prone)?
It is on my mod list tho. |
Drives: 2007 Yaris Hatchback Join Date: Jun 2009
is there a difference between a rear sway bar and a rear sway link brace?
| DIY - rear sway bar [pics] | cali yaris | DIY / Maintenance / Service | 199 | 07-28-2022 06:25 AM |
| Which front bar do you prefer? Strut or Sway? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-16-2009 12:52 PM |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 02:05 PM |
| TRD sway bar and tire wear | Cutie Pie #2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 02-01-2009 09:07 AM |
| Sway bar opinions | Nelson | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 24 | 12-10-2008 07:40 PM |
