![]() Drives: '08 hatchback, '90 325i 'e30' Join Date: Oct 2008
Fogs with highbeams
I'm rolling around the idea of putting 3000k HID fogs in, but I'd like them to be lit with the highbeams.
I did a search and found this: http://www.yarisworld.com/forums/sho...light=foglight I have an 08 LB S-model with stock fogs. Is there a relay I can jump so that when I turn my fogs on...they're on...and when I turn them off...they're off rather than them being on with low when the switch is on and the fog lights off when the highbeams are engaged? My reasoning would be I work 3rd shift and drive at night mostly, so I'd like more visibility, but I'd also like the HID's to be on from the time I switch my foglights on until I turn them off or turn off the car to prolong the life of the bulbs and also gain a little extra night vision while having the highs engaged. Let me know of any ideas. Thanks in advance. |
legal or not...I would put a vast sum of money on the number of times I've seen an SUV or a Jeep switch from Highbeam to Lowbeam and there were 4 lights before and after the switch....
#3 | |
Start another Oil Thread!
simply change where the foglight relay gets it's signal :)
you nailed it sir.
╚══════════RN
Why do you all have such difficulty seeing at night?
#6 | |
someone post a pic of the EWD and i'll draw it for you all
you nailed it sir.
I work 3rd shift. This is my nightly commute:
http://maps.google.com/maps?f=d&sour...,1.056747&z=11 My current standing record is seeing 14 deer between Troy and Southport on rt. 14 (1 way). Just because I have comprehensive insurance, doesn't mean I want to use it. |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
ill take pictures tomorrow if u have day time running lights u take out the relay... and then take the foglight wire and insert into the relay harness to match colors but ill take pics to show where it goes.. once u do this u can turn ur fogs on and off as u please... just dont forget to turn them off when u get outta ur car
"It hurts more when its wet" |
#9 | |
![]() mine are wired too stay on with high beam . |
To make the fogs work with hi or lo beam with the OEM headlight stalk with the fog light switch, snip the orange wire going to pin 4 on the stalk connector, tape or wirenut them so they won't touch anything, and then ground pin 4 at the connector. Once you do that, the fogs will come on regardless of headlight mode.
Conn D4 - Headlamp Dimmer SW Assembly.jpg |
#11 | |
Good lookin' out, CT!
yup thanks thats what i was going to take a picture of
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
ive never understood why foglights need to b e off for highbeams to engage in automobiles.. seems to me when your highbeams are on, its extra important to have your fog-lights on as well so you can still see the ground directly infront of you.
#14 | |
because fog lights are for FOG, and everyone knows you don't run your HIbeams in FOG lol
you nailed it sir.
okay when i'm on a country road at night time, and i want maximum visibility, and there is NO fog.. why cant i use both if i want? Turning off the fog-lights when you use your highbeams makes no sense. un-educated drivers will most likely put their highbeams on anyway, and end up disabliting their foglights.
my fogs stay on all the time, must be wire like CTScott's advice.
#17 | ||
you nailed it sir.
In New Zealand , they call them driveing lights if they
stay on with high beam . and fog loights if they turn off
| fogs + better pictures | TickleTimeTim | Cosmetic Modifications (Exterior/Interior) | 12 | 05-15-2009 09:57 PM |
| Smoked Fogs | TickleTimeTim | Cosmetic Modifications (Exterior/Interior) | 17 | 02-22-2009 02:20 AM |
| Question about fogs | custom Lftback | General Yaris / Vitz Discussion | 4 | 01-30-2009 12:11 AM |
| Chrome turn signal bulbs/yellow tint'd fog's | blacksandiegovitz | Cosmetic Modifications (Exterior/Interior) | 26 | 01-15-2009 01:05 AM |
| HID KIT and FOGS | falkor_99 | Photo-Video-Media Gallery | 31 | 07-05-2007 11:49 AM |
