Old 09-15-2009, 12:36 AM   #1
navydoc88
Drives: Yaris S sedan
HID kits?
so ive had my yaris for sometime now and i really want hid's but im very cautious to buying a kit and it not work on my car. who has installed them and where did u get your kit from
navydoc88 is offline   Reply With Quote
Old 09-15-2009, 12:39 AM   #2
EleKid
Eugenie たでし
EleKid's Avatar
Drives: '09 Blazing Blue Liftback
Xentec 8k's
EleKid is offline   Reply With Quote
Old 09-15-2009, 12:39 AM   #3
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
drop in HIDs are easy to put on, go with Bi-xenon they have better cutoff, however that is only in comparison with single beam HID, for true HID affect of dramatic cutoff you will need to do a retrofit. Caliyaris on this forum sells both. There are FYIs on the install.
Check out my Build thread:
Old 09-15-2009, 12:48 AM   #4
http://shop.microimageonline.com/cat...?categoryId=16
There you go. I've seen the actual kit in person, and it is nice. Works very well, unlike my eBay kit. The projector kit is very nice if you have some extra cash. It gets rid of the glare that a drop in HID kit produces in a halogen housing.
Old 09-15-2009, 01:05 AM   #5
navydoc88
thanks everybody. on those projector kit do i have to cut to fit that in the headlight housing or does it drop in
Old 09-15-2009, 01:11 AM   #6
You'll need to use a dremel to make the hole slightly bigger, but nothing too hard. There are two DIY guides here that you can use to install them.
Old 09-15-2009, 07:51 AM   #7
LEGATO``
LEGATO``'s Avatar
actually navydoc88 has a sedan and i believe no dremel was needed when Brian installed his when it came to actually putting the actual projectors themself in
he only used it when putting the amber panels back in
all you gotta do is open the headlights up and follow each step precisely as stated in the DIY
Project LEGATO
Old 09-15-2009, 11:35 AM   #8
Brian
Brian's Avatar
The projectors are a perfect fit in the sedan headlights. The only cutting that is required is to notch
the turn signal housing so the bottom of the projector doesn't hit it.
Old 09-15-2009, 01:04 PM   #9
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Yah, brian and camell both didn't need a dremel for the projector to fit in the housing. Only I needed it for the liftback. Either way, it was a MINOR task, if even that.
Old 09-15-2009, 08:22 PM   #10
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Originally Posted by bimmer4life2009 View Post
I need a new kit too
ninja sig spam!
Old 09-15-2009, 07:17 PM   #11
Oh!!!! hahaha, I just remember seeing dremel in one of their threads. I thought they used it to make the hole bigger. My bad.
HID kits - $115 shipped! cali yaris Sponsors Classifieds Area 18 07-25-2012 09:16 PM
FS Onyx HID Kits JM Auto Racing Items for Sale by private party 5 07-23-2009 12:08 AM
FS: Onyx HID KITS JM Auto Racing Items for Sale by private party 29 06-04-2009 03:55 PM
HID Blowout F1Spec Kits! 365Motorwerks Sponsors Classifieds Area 30 04-05-2007 12:38 AM
