Old 08-14-2009, 04:28 PM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Technical question about bigger injectors
This question is fuel economy related but I wasn't sure if the people in the FE forum were very technical.
If you swap out the stock injectors for bigger ones AND during normal driving you stay in closed loop mode... i.e. wideband air/fuel mixture is normal at 14.7... are you getting the same gas milage as if you had stock injectors?
My guess is yes. If the ECU is able to maintain an AFR of 14.7, it is metering back the gasoline to the same flow as the stock injectors.
The reason I ask is whether one can trust their data logger or ScanGauge so long as the AFR stays at 14.7. No boosted driving is involved during this gas milage run.
Old 08-14-2009, 04:34 PM   #2
yes it's ALMOST the same. If the air/fuel ratio is the same and the amount of air is the same, then the fuel used is the same.
However, as injectors get bigger (for the same purpose) the resolution goes down. My 632cc injectors are at a VERY low duty cycle when not in boost, so I am using up some extra gas because of that.
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 11:11 AM
Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? trini_per4mance Forced Induction Forum 19 05-06-2009 02:18 PM
bigger injectors? xxae07xx Performance Modifications 6 12-31-2008 06:04 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
Technical Question for the Suspension Gurus KwonSau Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-22-2007 12:31 AM
