Old 07-15-2009, 01:58 PM   #1
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Where can I buy a new engine?
Hi
I want to replace my stock 1,3 87hp. engine.
Does anybody know where I can get a bigger engine, doesnīt have to be brand new. I know the Toyota Yaris/Vitz in Japan can be bought with a 210hp. engine, but something less is ok.
Any help would be great, as I canīt find a place to buy it.
Regards Steven.
Danish Yaris is offline   Reply With Quote
Old 07-15-2009, 02:01 PM   #2
Tamago
Tamago's Avatar
Drives: ZZW30
i know you're not in the united states but.
www.car-part.com
Tamago is online now   Reply With Quote
Old 07-15-2009, 02:06 PM   #3
Danish Yaris
Hi
Thanks for the link, I would just get it shipped if I can find it.
I have looked a little at the webpage, but it seems like itīs only the 1,5 engine, I would like to get at least the 1,8 engine with about 130hp. Is that avaible from new in the US?
Regards Steven.
Old 07-15-2009, 02:21 PM   #4
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
You know it will probbaly be ALOt cheaper to just go and buy a Yaris TS 1.8?
Old 07-15-2009, 02:23 PM   #5
supmet
Drives: 2007 4 Door Yaris
Originally Posted by Danish Yaris View Post
Hi
Regards Steven.
We don't get the 1.8 in the US, because we have the xD
Old 07-15-2009, 02:40 PM   #6
If you want a 1.8L, which is the Yaris TS motor in Europe, why not get one in Europe?
Old 07-16-2009, 02:13 PM   #7
Danish Yaris
Hi
I canīt find one in Denmark, not many T-Sports in Denmark. I canīt find a European webpage that are selling used engines for Toyota, it would probably be a lot cheaper to buy it in Europe.
Itīs not cheaper to buy a T-Sport in Denmark, the cheapest one is just over $53.000 plus met. paint and license plates.
I have bought the Sol model which have just a little less equipment than the T-Sport, but only 1,3 engine with 87hp. I bought it two years old for $32.200, price for a new one was $46.500.
So I think itīs still cheaper to buy another engine.
Regards Steven.
Old 07-16-2009, 03:05 PM   #8
It sounds like it might be better to just get the engine.
It just seems like used parts are available SOMEWHERE in Europe? Don't they have salvage yards over there?
Old 07-16-2009, 04:09 PM   #9
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
Hehe... living in the US we separate the fractional portion of a number from the whole portion of the number using a period, not a comma... we use the comma for separating the thousands digit from the less significant digits... at first glance that reads to me as:
I want to replace my stock 1,387hp (one thousand three hundred eighty-seven) engine... DANG that's a powerful stock engine! :-)
twowheels is offline   Reply With Quote
Old 07-16-2009, 04:48 PM   #10
CASTREX
CASTREX's Avatar
You also need to concider that swaping engines is not as simple as it sounds...
If you find a 1.8L engine then you will need the ECU for that engine and might even need the transmission.
The engine mounts will be different, so it will require some custom work to install the larger engine. Al perpherals will change... so you will need the intake and exhaust manifolds and also some custom work to mate the exhaust manifold to your current exhaust...
Also you will probbaly mess up with other car functions that are controlled by the OE ECU such as trac control, ESP, dash warning lights and instrumentation.
In other words... when you are doing a one of a kind (read no Honda swap) you have to be ready to deal with a lot of stuff that you will find in the way.
If you are looking for extra power... have you concidered going the turbo route?
Still will probably have to be all custom made but it should be cheaper and easier than swaping engines.
Old 07-17-2009, 02:07 AM   #11
djgab101
djgab101's Avatar
Drives: toyota yaris
if it was me... i would rather remove the stock engine and put in a 2zz ge engine from a Celica.... which gives you 142 kw...
there has been pics of it done... but not much...
djgab101 is offline   Reply With Quote
Old 07-21-2009, 01:23 PM   #12
Danish Yaris
Hi
Would the Toyota Celica engine fit in the engine room? I thought it was bigger.
I know I have to get another ECU, wiring etc.
I also thought of the turbo and would like to have that, but no one makes a turbo kit for my engine.
Regards Steven.
Old 07-21-2009, 01:42 PM   #13
CASTREX
CASTREX's Avatar
A turbo kit would have to be custom made... but it will require LESS amount of custom work than a swap.
In other words, if you are afraid of the custom work that a Turbo kit would require... don't even think about the swap.
It will be more work and will probably end up costing more.
And yes, we've seen a few pitures of 2ZZ engines stuffed on a Yaris. It is larger, you are right. Probably some chassis cutting here and there would be required...
Old 07-21-2009, 03:29 PM   #14
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
buy a ts. you can find a used one...
other suspension, other brakes... other car!!
yaris 2sz is offline   Reply With Quote
Old 07-21-2009, 03:44 PM   #15
markitect
Drives: Yaris
I think you guys seriously underestimate the cost of buy a new car in Denmark. For their total out of pocket you could walk into a US dealership and talk them down to getting 3 cars for that much money.
You gotta keep the allzoner price down somehow.
markitect is offline   Reply With Quote
Old 07-27-2009, 12:06 AM   #16
botchilah
Drives: white and red shiny things
There's a whole lot of salvage yards and breakers in the UK. I think your best bet is to start there. If you would like to buy straight from Japan, YAM Auto (I think that's the company's name) can import you almost anything you want (cars, parts, used engines, tuner crate engines etc) from Japan straight to Europe. Good luck!
08' Yaris HB 5dr: RAYS 57 Motorsports 17X7 / K&N SRI / TANABE axleback exhaust / ULTRA RACING complete braces / MEGAN RACING complete braces / NEX coilovers / NEX 330mm 4-pot front BBK / PENGUIN GARAGE hub spacers / HOTBITS headers / BUDDY CLUB oil cap and rad cap / APP SS brake lines / HKS synthetic lubes / RECARO SR5 seats / TRD shiftknob / cheap FEDERAL (free) tires lol. NEXT: HKS F-CON iS
botchilah is offline   Reply With Quote
Old 07-27-2009, 01:27 PM   #17
Danish Yaris
Hi
Thatīs for the link to the Japan dealer name.
Regards Steven.
Old 07-28-2009, 02:16 PM   #18
Danish Yaris
Hi
I canīt find any info for Yam Auto at google. Does anybody know what their website adress is?
Regards Steven.
90% on short trip. What to do to protect engine? lh59 DIY / Maintenance / Service 22 12-17-2008 10:02 AM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 04:59 PM
GROUP BUY ZETA PRODUCTS YARIS LIFTBACK ARMREST zetaproducts.net Sponsors Classifieds Area 29 11-13-2008 01:37 PM
