Old 08-04-2009, 01:42 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
anyone got fogs on 09?
im looking to doing up fogs on my 09, iv seen lots of pre 09s with them, anyone have them on their 09? (i know what i need to get, just i want to see pics of them installed)
im also wondering what would look better on my Meteorite Metallic, clear (yellow bulb)/(hid so it wont be yellow bulb) or yellow lens. Im not sure if id like seeing a yellow bulb all reflected on the housing when its not on.
Check out my Build thread:
Old 08-04-2009, 03:13 AM   #2
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Here you go:
'09 Yaris with fogs (clear lens) and Nokya Hyper Yellow (2500K) halogens.
Old 08-04-2009, 09:10 AM   #3
Quite a few of us with 09's have installed fogs. I went with the clear lens kit from MicroImage, but he also carries yellow a lens kit.
Old 08-04-2009, 09:20 AM   #4
Keith Tinari
Scrubble with a poke.
Keith Tinari's Avatar
Drives: 2009 Yaris LB
What does Garms switch look like installed? I want to get a set too.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen
Keith Tinari is offline   Reply With Quote
Old 08-04-2009, 09:24 AM   #5
It looks like the OEM center console switch or any of the other aftermarket kit switches. I don't have a pic of it, as I decided to use my own. I wanted the switch to be next to the dimmer rheostat, instead of in the center console.
Old 08-04-2009, 09:28 AM   #6
Keith Tinari
The for switch isnt on the stalk from the factory? Its a seperate button near say the Aux port?
Old 08-04-2009, 09:31 AM   #7
There is an OEM stalk with the switch built in for factory fogs, and the there is an OEM center switch (which I believe is used for port/dealer installed fogs).
Old 08-04-2009, 09:31 AM   #8
Keith Tinari
Oh okay! Sounds good to me then!
Old 08-04-2009, 11:02 AM   #9
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Can't recommend the new wiper switch enough. It's OE and lights indicate the fogs are on in the dash (car pre-wired). Well worth the money. Removing the wheel is super easy as well thanks to write-up here on YarisWorld.
DerFlosser is offline   Reply With Quote
Old 08-04-2009, 11:09 AM   #10
Keith Tinari
how much more does that run? I mean if you buy garms kit and then the stalk? I would prefer them on the stalk too but for 100 i wont complain especially if its still almost oem.
Old 08-04-2009, 11:46 AM   #11
90tsi
90tsi's Avatar
Drives: 09 yaris
I put the oe light stalk on.its easy... my issue I have is I did the switch, relay, and fuse but I can't seem to find he power in that relay box behind the LS headlight. im sure I just have something not quite right
90tsi is offline   Reply With Quote
Old 08-04-2009, 12:00 PM   #12
See the two red wires on the bottom left (on the connector full of greens). Either of those two positions will work for +12 V power and then you use the ground bolt under the LS headlight for the ground connection.
Old 08-06-2009, 12:36 AM   #13
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
I have the factory ones...
RUFFSTUFF is offline   Reply With Quote
Old 08-06-2009, 01:36 AM   #14
IsLNdbOi
IsLNdbOi's Avatar
Anyone make a complete fog light kit yet for the '09s? I don't want to buy an '07/'08 kit and then have to buy the bezels for the '09.
Old 08-06-2009, 03:20 AM   #15
ezhacker1
ezhacker1's Avatar
i guess we will need to wait a little longer...same goes for the head and tail lights.
Old 08-06-2009, 07:26 AM   #16
Keith Tinari
Garm at Microimage makes and sells this kit. Very cheap too.
Old 08-06-2009, 07:34 AM   #17
IsLNdbOi
IsLNdbOi's Avatar
Does his kit come with the '09 fog light shrouds?
Edit:
Just checked. They don't.
Old 08-06-2009, 08:10 AM   #18
spookz
JDM yO!
ESUSE does make a kit for the '09 Yaris. It's part number is FL-TY048. Where as the 06+ Yaris was FL-TY038.
Fogs with highbeams rhino5 Cosmetic Modifications (Exterior/Interior) 20 06-30-2009 02:43 AM
fogs + better pictures TickleTimeTim Cosmetic Modifications (Exterior/Interior) 12 05-15-2009 09:57 PM
Smoked Fogs TickleTimeTim Cosmetic Modifications (Exterior/Interior) 17 02-22-2009 02:20 AM
Question about fogs custom Lftback General Yaris / Vitz Discussion 4 01-30-2009 12:11 AM
HID KIT and FOGS falkor_99 Photo-Video-Media Gallery 31 07-05-2007 11:49 AM
