Old 09-05-2009, 01:04 AM   #1
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
One filament in the headlamp bulb.
Am I missing some detail about the Yaris headlamp bulb? On-line I was looking at different Yaris headlamp bulbs. The headlamp bulb is listed as 65/55W. But all I could see in the clear headlamp bulbs is just one filiment. It looks like the Yaris uses resistors and/or relays to create high beam, low beam and daytime running lights. If I am right, when the DRL burns out the filiament in the headlight bulb, you need to replace the headlamp bulb before dark (or have fog lamps as a backup plan) to avoid driving a one eyed monster.
ellenbetty is offline   Reply With Quote
Old 09-05-2009, 04:44 AM   #2
RedRide
RedRide's Avatar
The yaris uses a 9003/H4 bulb with two filiments.
The DRL uses the low beam (at lower voltage) so, yeah if you loose a DR, replace the bulb ASAP.
Old 09-05-2009, 06:52 AM   #3
goku87
goku87's Avatar
Drives: Black HB
one of my headlights looks sad. is this why? one of the filaments died?
goku87 is offline   Reply With Quote
Old 09-05-2009, 12:13 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
yeppers, you will not see the 2nd filament by looking through the headlight assembly.
Also, if one of your headlight look very DIM compared to the other, you could have a bad ground somewhere... check all your wiring.
Old 09-05-2009, 12:29 PM   #5
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
When a headlight does need replacing, it's best done in matching pairs. Replace one, and the two will probably not appear the same color and brightness.
Old 09-05-2009, 07:19 PM   #6
RedRide
RedRide's Avatar
Also, once one goes, the other is living on borrowed time.
Old 09-06-2009, 11:18 AM   #7
ellenbetty
ellenbetty
ellenbetty's Avatar
Found this at Candle Power Inc. Diagram shows 2 filaments. Front filament for high beam. Rear filament for low beam. Not the best diagram.
Old 09-06-2009, 02:30 PM   #8
RedRide
RedRide's Avatar
Interesting read. The PDF explains the "difference" between a 9003 and H4 and clears that up.
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 01:02 PM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 07:40 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
Yaris Hi-Beam Light Bulb Type jesse1000 Canada 3 01-11-2009 09:59 PM
The right fog light bulb exploded and cracked the lense vacantj DIY / Maintenance / Service 1 08-01-2007 05:07 AM
