![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
Which is more wise
If I were have to run a 400km straight road, in terms of fuel efficiency. Which one would be better? No a/c, drag or whatever other factors involved.
Yaris going at 160kph/100mph = 2.5Hrs Or 80kph/50mph = 5Hrs The rule is to save as much fuel as possible. Cheers
Not quite a noob
80
160kph for 2.5 hrs = road side suspension What are you getting at here?
Despite the road limit. 80?
![]() ![]() Drives: 07 Mazda MX5 Copper Red Join Date: Jun 2009
80kph/50mph = 5Hrs
If you are trying to use as little fuel possible, stick with the speed that nets you more mpg. |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Somewhere between 35 and 45 MPH, depending on the road and weather conditions, and any elevation changes.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
45mph = approx 70kph
Thanks |
You forget wind resistance. Higher the speed, the more it sucks.
60kmh in 5th gear is the best fuel saver. But you have no choice but to go faster at the slightest incline.
#12 | |
Half a Bubble Off Plumb
The correct answer has been given several times already. |
