Old 09-20-2009, 05:44 AM   #1
texkid
The one with cheese on it
Drives: '10 Corolla S
Such an idiot, I am! (short shifter related)
Well, there were some talk about the SSK-2 coming loose at times. But I never listened. There was a member whose [*sp?] SSK-2 actually came off while on the road. But I didn't listen.
Now, at around 10:00 PM on route to Katz Deli for a friend's birthday party, what happened? My freaking SSK-2 came off and I was in NEUTRAL for a good quarter mile (not bad of a rolling distance if you ask me). It is semi-dark, a Saturday night, in downtown Houston, and my tool box is at least 20 miles south. What did I do, you ask? I grabbed my Benchmade pocket knife, cut around the bolt holding down the center console, reached under the shifter, took off whatever was left of the SSK-2, re-attached the plastic "coupler" from the shifter cable to the shift-stick and continued driving with a chopped up center console in the back seat.
In the end, I got home with a chipped nail (like i ripped off some skin with that nail), broke the tip of a very nice pocket knife which is going to be a female-dog to grind in a new tip for, and I am going to need to find a new center console.
Would I do it again? Hell yeah! That is one bad ass SSK-2. Only this time I will heed to the warnings and apply some fancy Loctite.
So please, learn from my mistake and apply some Loctite (or equally strong adhesive) to the screws of the SSK-2. Or else you'll end up going McGuyver on your car. Believe me, its amazing how a flashlight doubles as a hammer.
ADDED NOTE:I finally woke up and took some quick pics. Enjoy!
What is if left of that hole. I don't think I can superglue that.
Poor thing...didn't see it coming.
I am still looking for that nail.
Sliced up finger when trying squeeze into that tight space under the shifter cage.
My precious blade.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 09-20-2009, 08:00 AM   #2
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
WOW! thats some quick thinking.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 09-20-2009, 08:39 AM   #3
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Your attitude about the whole thing is what is most impressive!
You didn't blame anyone, and got the job done.
I'll be getting an incab ssk soon. I'll take yor advise.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 09-20-2009, 12:43 PM   #4
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
^^+2
Thanks for the heads-up on the loctite .
Old 09-20-2009, 08:34 AM   #5
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
haha, wow, very resourceful.
Old 09-20-2009, 09:02 AM   #6
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
! you are now ready to drive a Ford! Anything can happen you will fix it or make it work!
the_boss is offline   Reply With Quote
Old 09-20-2009, 03:55 PM   #7
texkid
Ah, you forget my friend. I owned a Ford Escort and a Ford Probe and my dad still owns his '93 Ford F-150. So I am used it.
I'll be getting an incab ssk soon. I'll take your advise.
I can't be mad at anyone. If anything, I was mad at myself for not having an "emergency set" of tools. At no point was I mad about chopping up my car, either. My main concern was keeping my wife safe.
DIY: A/C Insulation
Old 09-20-2009, 04:08 PM   #8
wow, that was super resourceful. I'm going to include instructions to use Loctite with that part. NST should do the same.
Old 09-20-2009, 04:55 PM   #9
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
no comment... not on this one..
Old 09-20-2009, 05:19 PM   #10
texkid
But you still felt the need to COMMENT "no comment"?
DIY: A/C Insulation
Old 09-20-2009, 05:31 PM   #11
RedRide
RedRide's Avatar
That must have been a nightmare!
Glad you got going again.
Emergencys are the exact reason that I aways keep some basic tools in all my cars
Things like a regular and phillips screwdriver, pliers, a small crescent wrench, and a small nut driver/ ratchet set can be invauluable at times. Add to that a good knife of course.
BTW, CT Scott is selling a console for $25
http://www.yarisworld.com/forums/showthread.php?t=21881
Old 09-20-2009, 06:17 PM   #12
texkid
I definitely need to get a quality Leatherman!
I just PM'd CTScott about the console. I called DIBS!
DIY: A/C Insulation
Old 09-20-2009, 07:38 PM   #13
RedRide
RedRide's Avatar
A "Leatherman" Multi tool can be handy at times.
However, there is no subsitute for the proper tool. The Yaris has too much storage capacity not to carry the basics.
Old 09-21-2009, 12:04 PM   #14
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
note to self, dont buy
http://www.4055design.com
Old 09-21-2009, 08:35 PM   #15
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
Actually this can be avoided by using loctite... which is recommended for most screws like the one that pops out on the SSK-2. Also, if you plan to mod your car it's always good to have tools on hand and/or spares (lines, belts, couplers, screws, bolts).
RacerFreakXXX is offline   Reply With Quote
Old 09-21-2009, 09:00 PM   #16
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Thougt i better check mine today , nothing better to do .
pulled the consol off looked at the SSK and oh i already had used thread lock , oh well i gave it a little lube instead , should have done that sooner wow , very smooth action now
1,500 volts direct current vs Idiot. EXTREME VIDEO FOOTAGE *MAD DOG* Off-topic / Other Cars / Everything else Discussions 31 06-09-2009 03:23 PM
I love idiot drivers in rental box trucks Black Yaris Photo-Video-Media Gallery 23 05-11-2009 09:33 PM
Idiot light? kelevra General Yaris / Vitz Discussion 17 12-14-2008 03:51 AM
temperature idiot light enough ? yaris-? New YARIS Purchase Forum 2 11-29-2008 10:18 PM
