Old 10-02-2009, 03:33 AM   #1
birdman
Drives: '08 Blazing Blue Yaris LB
front sway bar install
Does anyone have info regarding the front sway bar install and performance?
birdman is offline   Reply With Quote
Old 10-02-2009, 10:26 AM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
1. don't do it, it's not a mod that will make the car turn better in any way. (i know from experience on my xA)
2. if you do do it, get an engine lift to support the engine while you drop the subframe out. don't forget to detach the steering linkage under the dash so it doesn't simply fall out. have a friend there to help you get the subframe back on the car afterword. then drive straight to get the car aligned, as the subframe will most likely be sitting crooked.
Originally Posted by xnamerxx
you nailed it sir.
Old 10-02-2009, 08:56 PM   #3
birdman
Thank you thank you thank you! I aina gonna dooit now.
Old 10-02-2009, 08:58 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
yeah, don't do it. Just get the rear one, and no alignment needed.
Old 10-02-2009, 09:03 PM   #5
birdman
Got the rear TRD one already. Had the TRD springs but took them off due to the harsh ride they delivered. Does moving up to a beefier sway bar or changing out various bushings for better ones noticeably help?
Old 10-04-2009, 09:41 AM   #6
Tamago
Tamago's Avatar
Drives: ZZW30
help in what way?
you nailed it sir.
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
Nitto front strut bar installed gmodder Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 03-20-2009 02:51 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 02:46 AM
C-One Front Sway Bar Jerkratt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 06-29-2007 11:33 PM
