Old 10-07-2006, 04:33 AM   #1
oscarying
Drives: SLOOWZ
Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII??
Does it work ??
oscarying is offline   Reply With Quote
Old 10-07-2006, 04:37 AM   #2
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Why to use it?
Old 10-07-2006, 04:48 AM   #3
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
I beleive Power Enterprise's CamCon works on our car and can modify the VVT-i engagement points.
paultyler_82 is offline   Reply With Quote
Old 10-08-2006, 12:12 AM   #4
oscarying
Drives: SLOOWZ
Originally Posted by Katana
Why to use it?
can't it make better fuel efficiency and can't it also make the VVTi activate earlier to give power rather than rev it??
i m not sure ..
Old 10-08-2006, 07:48 AM   #5
Katana
Katana's Avatar
Sounds nice idea.
Old 10-08-2006, 06:13 PM   #6
ChinoCharles
Drives: LB
Like a VTEC controller for Hondas, eh?
Old 10-08-2006, 10:37 PM   #7
oscarying
Drives: SLOOWZ
yes,exactly,but i m just not sure it can be applied on yaris or not...
Old 10-09-2006, 02:09 AM   #8
EnduroMTS
Drives: 2007 Toyota Yaris
Send a message via AIM to EnduroMTS
Im almost positive it wotn help the Yaris much. We hooked up one on the Celica, VVTL-I GTS didnt do anything but actually cause problems. Might be different for the yaris, but If it works let me know :)
EnduroMTS is offline   Reply With Quote
Old 10-09-2006, 04:01 AM   #9
oscarying
Drives: SLOOWZ
what problem does it cause?
i would like to make sure it helps before i buy it ...cause i know it helps on
Vtec engine,but just not sure it helps on VVTi or not
Old 10-09-2006, 07:43 AM   #10
Katana
Katana's Avatar
Ι think you won't have steady engine rpms.
Old 10-09-2006, 09:34 AM   #11
oscarying
Drives: SLOOWZ
but does it really help on fuel ratio and controlling the vvti ?
I 've seen people installed on ECHO on the nets before with the pen-shape turbo timer...why they installed a turbo timer on a NA echo...with SAFC...
i don't know...may be it gives a ricer impression??that's why i m asking since the SAFC has a good looking and if it really helps the engine i will go for it,
but if not..i won't
Old 10-09-2006, 09:49 AM   #12
Katana
Katana's Avatar
Without being a mechanic, I am of the opinion that it won't help.
Old 10-19-2006, 10:39 AM   #13
firefly1_0
What the...?
firefly1_0's Avatar
Drives: '06 Blazing Blue 3 door RS.
there is a big difference between Vtec and VVt-i. an engine with a performance based thing like Vtec and an economy based thing like VVt-i place it in two different worlds.
think about how they both work. honda's will change the valve train to a bigger lift and bigger overlap at a specified RPM, it never changes unless you have an aftermarket ECU that you can change the engagement point.
VVt-i will only change the timing of each cam and its constantly evolving during engine operation.
you want more power in these things, buy a compresser, or swap in something else...
my other car is still faster...
...and the engine is way smaller.
silly ricer, useless wings are for penguins...
firefly1_0 is offline   Reply With Quote
Old 10-19-2006, 12:44 PM   #14
Katana
Katana's Avatar
...exactly!
Old 10-19-2006, 07:46 PM   #15
hosmer
VVTrouble
hosmer's Avatar
Drives: 07 Yaris LB...BS, MT, PP, ABS
Send a message via AIM to hosmer
VVTi - controlled by the TPS (throttle position sensor)
Vtec - controlled by engine RPMs
The VVTi advances timing and starts the valve overlap as soon as you put your foot (about) 3/4 of the way to the floor and returns to "normal" when cruising....theres no real way to change the engagement time
Vtec is a whole seperate cam profile where the camshft actually slides over to a more aggressive profile (Vtec camshafts have 3 sets of lobes for each cylinder). So with an aftermarket controller you can activate the aggressive cam profile sooner getting a bit more power
Toyota VVTi (1JZGTE) HKS cams:
Honda B16A cams (3 lobes per cylinder):
hosmer is offline   Reply With Quote
Old 10-19-2006, 08:57 PM   #16
paultyler_82
I know that overriding the ECU on Nissan engines to modify the CVVT helps performance, but maybe Nissan goes about things a different way, basically, CVVT advances the cams forward under heavy throttle to give more performance, until it senses knock, then it retards the cam back a bit.
Old 10-20-2006, 10:41 AM   #17
cdydjded
Drives: Yaris LB Turbo
Sorry guys but VTEC is not just an RPM function. It works with RPM's & an oil pressure activated solenoid. The solenoid opens @ the factory preset 4800 rpms which engages the 3rd lob on the cams. Just by engaging the VTEC funtion @ an earlier or later rpm will NOT give you more power unles you add more fuel. If the cam opens more (more lift) the motor needs more fuel. The advantage of a SAFC or the CamCo is really the ability to controll your engines fuel curve. If you put you car on a dyno & find that it is running lean or rich @ a certain rpm you can add or subtract fuel to fix you fuel curve.
Also VVTi does do the same as VTEC. VTEC is done with a 3rd lobe, VVTi is done with a sliding pin. Go here http://en.wikipedia.org/wiki/VVT-i if you want an exact explination.
cdydjded is offline   Reply With Quote
Old 10-20-2006, 03:36 PM   #18
firefly1_0
What the...?
firefly1_0's Avatar
i'm sorry,
there is a huge difference between valve overlap and bigger lift on a third lobe then there is in a variable overlap system like VVT-i.
VVT-i does nothing for adding more lift...
there is nothing that says that VVT-i adds power. VTEC does...
