Old 04-22-2016, 06:43 PM   #1
Chris Jackson
Drives: 2008 Toyota Yaris Hatchback
Noise From ABS when Braking + ABS & (!) Light On - Please Help
Hi guys,
I have a 2008 Toyota Yaris that is causing me a lot of trouble, and money with the ABS. Since December, the ABS has been causing me a lot of problems with this car. Sometimes when I brake there's a loud grinding noise coming from the ABS. Usually after this occurs the ABS & "!" Lights will come on signally that the ABS is turned off. Also, when it makes this noise the car doesn't break as smooth or rapid, it kind of slowly creeps forward while making the noise. The noise only occurs when the lights AREN'T on. You can see a link to the video I made at the bottom to see the problem for yourself.
I have been to the mechanic 3 different times. I've had a bunch of new work done to the brakes themselves so I know thats not the problem. I've gotten a new ABS sensor. And today I just got back from the mechanic after he installed a new bearing, just to drive back home to find the ABS making the same noise and problem.
Does anyone know what I should do? ANY suggestions help. Thanks!
Here's the link to the video: https://www.youtube.com/watch?v=gf26ea7DzP4
Chris Jackson is offline   Reply With Quote
abs light on brieghne DIY / Maintenance / Service 1 02-23-2012 09:30 AM
ABS light on.... Do'h! BURRITO General Yaris / Vitz Discussion 3 11-27-2011 09:02 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
Noise when braking hystria DIY / Maintenance / Service 9 05-02-2007 10:28 AM
ABS....Again~~ MeggiemobileSFLA DIY / Maintenance / Service 11 04-03-2007 10:12 AM
