Old 09-18-2009, 09:09 AM   #1
UncleMo
Drives: 2007 Yaris Sedan base model.
The Bars and MPG question
Hi. You know how there are 8 bars that show you how much fuel you have? How is it possible that I went 62 or 63 miles before the first bar went away. If my estimates are correct, I should get 496 total miles out of my entire tank if this holds up(62 * 8 = 496 total miles). If you take 496 and divide that by 11.1, which is the tank size for an 07 sedan, you get 44.68 mpg. How is this possible when fuel economy.com told me I would get 29mpg (city)?
UncleMo is offline   Reply With Quote
Old 09-18-2009, 09:20 AM   #2
DevilGirl
Drives: 09 3dr LB MT
EPA estimates are never all that acurate. As far as miles per bar, I'm not positive on how the tank is on the Yaris, but I know on all other cars I've owned, the first half of the tank goes slowly, and the second half runs through pretty quickly, due to the shaping of the tank. I've generally been getting about 350-370 miles to the tank, (refueling when the last bar starts to blink, or shortly thereafter), with an average MPG of about 37.5.
Old 09-18-2009, 12:07 PM   #3
Zaphod
Drives: Big Yellow
500 miles on less than 10 gallons is totally possible with restraint in the right driving conditions.
Like everyone says, those 8 digital partitions don't necessarily represent equal measures of gas. That's why everyone just waits to do the division when they fill up.
Still, you may have found a car that just really compliments your driving technique.
Zaphod is offline   Reply With Quote
Old 09-18-2009, 11:46 AM   #4
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
You might be over-filling the tank by topping it off after the pump clicks off. This will give you more miles on the first bar, but it is not a good thing to do. They warn you that you can mess up your fuel tank vent system by over-filling the tank. I used to be guilty of that practice, but now I just stop filling the first time the pump kicks off.
Tom
YarisOwnersDad is offline   Reply With Quote
Old 09-18-2009, 12:56 PM   #5
UncleMo
Well I must say I did baby it. I usually drive like I just busted out of prison and there are points to be racked up if I hit pedestrians.
Old 09-18-2009, 01:35 PM   #6
DevilGirl
I hear it was 50 points a ped... 100 for babies in strollers... 25 for old farts (they can't move to get outta your way, and they're at the end of their life cycle)....
Old 09-18-2009, 02:07 PM   #7
b_hickman11
Drives: 08 Sedan
62 miles on the 1st bar is not bad but you could do a lot better. I average around 80 for the 1st bar. The most I ever got on the 1st bar was around 120 miles. Most fuel gauges are not accurate in the sense that there is an even amount of gas for each bar or for each tick on the old style.
b_hickman11 is offline   Reply With Quote
Old 09-18-2009, 05:10 PM   #8
09box
Drives: 09 grey Yaris hatch
I usually don't go more than 30 miles when the last bar starts flashing. I've already learned my lesson after running out of gas. Usually now, I fill up 20-25 miles after the last bar starts flashing. I've been getting about 380 miles on a tank lately.
09box is offline   Reply With Quote
Old 09-18-2009, 05:39 PM   #9
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Not all bars are created equal just like the old analogue gauges each bar will give differing mileages.. 45mpg should be easily attainable in your Yaris..
Old 09-19-2009, 07:07 PM   #10
Forrest
Drives: 08 LB BLACK
The bars...are only estimates. You will not get the same amount of miles on each bar. They are only an indication of approximate amount of gas you have in the tank and when you need to refill.
Forrest is offline   Reply With Quote
Old 09-29-2009, 10:53 PM   #11
Keith Tinari
Scrubble with a poke.
Keith Tinari's Avatar
Drives: 2009 Yaris LB
mine has changed since I bought the car and gotten even worse since I have "modded" it. I have a K&N drop in and the TRD axleback and drive fairly conservatively. I went from dropping the first bar at 80-100 miles to last week when I reset the ECU for the filter and axleback and dropped the first bar at 66 and second bar at 89. What gives? I get gas from the same sunoco station I have always gone to for the last say 4 years.
"If you cannot find truth right where you are, where else do you expect to find it?" Dogen
Keith Tinari is offline   Reply With Quote
Old 09-30-2009, 09:14 AM   #12
DevilGirl
Always possible that the gas station had a bad mix come in. I've had that. Same place for quite awhile, driving habits hadn't changed, but got either waaaay better or significantly worse. Bad shipment I think.
Old 09-30-2009, 12:28 PM   #13
SaerinRhoe
'09 Yaris
Drives: '09 Yaris
I've gotten 84 miles before losing the first bar so I don't think there's any exact measurement for it. As for fuel mileage, I've gone 440 miles on a tank before the last bar started its slow blink.
One of these days I want to drive it all the way to the end just to see how far I can get on a complete tank but I've not had the time yet.
S.R.
2009 Yaris 3-Door Liftback MT Black Sand Pearl
SaerinRhoe is offline   Reply With Quote
Old 10-01-2009, 10:56 PM   #14
jtcoop
jtcoop's Avatar
Drives: 07 Yaris, LB, MT, Bayou Blue
Another way to look at it
If you divide the 11 gal tank by 8 you would have 1.375 gallons per bar. Let's say you are getting 40 mpg. Multiply 40times 1.375 to get 55 miles per bar. Since most are getting 60+ miles or above before the first bar goes out it would stand to reason that the bars are not equal. I have even noticed that I can not double the mileage between the first and the second bars. I doubt I will try and drive 55 miles after the last bar starts flashing.
Is it just me or does the flashing get faster the longer you drive?
jtcoop is offline   Reply With Quote
Old 10-02-2009, 12:15 AM   #15
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
yes, it flashes slow at approx 1/8 tank, very fast at 1/16 tank.
Old 10-02-2009, 02:33 PM   #16
b_hickman11
Drives: 08 Sedan
So in other words the Yaris's fuel gauge is exactly like the older type gauges. You could drive for miles and miles before the needle would budge even a little but after that the needle would start to drop very fast.
Old 10-05-2009, 12:02 PM   #17
bronsin
bronsin's Avatar
Not only that but youll never get the mileage out of the last four bars that you did on the first four...I would love to have a flow gauge which accurately measured how much fuel you are REALLY using.
Old 10-03-2009, 04:47 PM   #18
AVIC-U310BT
Drives: 2007 Yaris Hatchback
All bars are not created equal.
I tested this a while back. I regularly get over 60 miles on the first bar, and less on the others. I too thought that it should accurately represent an eighth of your tank. That's how I lost the bet with the girlfriend. Luckily, she already knows I'm always wrong. :)
AVIC-U310BT is offline   Reply With Quote
195/60-15 Tires, premium and MPG Henry G. Fuel Economy Forum 24 09-10-2009 02:42 AM
For those that hammer the throttle, whats your average lowest mpgs? detroiter Fuel Economy Forum 65 02-07-2009 12:24 PM
To accurately measure MPG when should I fill back up. mgthompson General Yaris / Vitz Discussion 17 03-30-2007 11:07 PM
