Old 10-30-2009, 05:38 PM   #1
Hakan
Drives: 2003 Yaris
Yaris engine durability??
I m curious How many kms or miles can a Yaris engine resist??
Hakan is offline   Reply With Quote
Old 10-30-2009, 06:48 PM   #2
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
over 9000
Old 10-30-2009, 06:57 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
there's at least one driver in the US with over 350k... I think there is another driver over 300k too. Those people have been delivery drivers tho who do hundreds of miles a day mostly on highways.
Regular driving I would expect an engine to last at least 200k with regular preventive maintenance (oil changes, air filters, and swaping other fluids when needed)
I'm currently at 38k... no problems with my engine.
Old 10-30-2009, 08:26 PM   #4
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I am at 145,000km with no problems. Other than my car being accident prone!
devinlamothe is offline   Reply With Quote
Old 10-30-2009, 08:39 PM   #5
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
This engine design has been around for a while prior to the Yaris, and it seems to be a typical Toyota motor. (I.E. Reliable and very durable)
Old 10-30-2009, 08:51 PM   #6
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
I think most Yaris' can make it off the lot. After that it's a crap shoot.
RUFFSTUFF is offline   Reply With Quote
Old 10-30-2009, 09:21 PM   #7
bear4
Drives: 2007 yaris
I have 2 echos which is the same motor as yaris. My 2001 has over 150,000 miles and no problems at all. Probably will have to adjust valves and replace timing chain by 200,000 miles. I use synthetic Mobil 1 oil since it was new.
bear4 is offline   Reply With Quote
Old 10-30-2009, 10:10 PM   #8
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Mine's made it nearly 7000 miles!
The 1NZ-FE is the same engine that was used in the Echo and in early Scions. It is basically the same as the engine in the first two generations of the Prius. (The 1NZ-FXE Prius engine came first, and the Echo/Scion/Yaris engine was a minor modification of it.) It has a good service record.
Old 10-30-2009, 10:23 PM   #9
Yaris Hilton
Smile
Hakan didn't say where he lives. The 1NZ-FE of which I spoke is the only engine used in the United States for the Echo, early Scions, and Yarises. The 1.3L 2NZ-FE is basically the same engine with a little shorter piston stroke. The 1L 1SZ engine is built by Daihatsu. The 1.4 liter turbo diesel's another option. None of those are available in the U.S. If the diesel were, I'd've bought one.
Old 10-30-2009, 11:24 PM   #10
Kal-El
Kal-El's Avatar
The member trini_per4mance has over 380,000 miles on his '07 with no problems.
This little 4-banger is bullet proof.
Old 10-31-2009, 12:31 AM   #11
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
Old 10-31-2009, 02:26 PM   #12
bronsin
bronsin's Avatar
Really! Do you have any other information about it? How interesting.
You can rest assured that the ECHO/Yaris engine is one of if not the finest engine EVER made for a motor vehicle. Its durable, powerfull, and gives outstanding FE.
Old 10-31-2009, 02:35 PM   #13
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
Can anyone name a toyota motor that isnt
Thej3sta2 is offline   Reply With Quote
Old 10-31-2009, 02:40 PM   #14
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
With proper maintenance 300,000kms is easily obtainable with no major problems.I'd be more concerned about the body rusting before the engine gives you any problems,If you are planning to drive the car for 10+ years a yearly oil spraying will be money well spent in preservation of the body.
http://www.krown.com/#process/
Old 10-31-2009, 04:23 PM   #15
Yaris Hilton
Smile
Toyota owns a big stake in Daihatsu. They've done a number of joint ventures.
Old 11-02-2009, 02:42 PM   #16
dorman68
Drives: Corolla
There is a guy on you tube with over 300k in his. Just do a search for 300000 mile toyota on you tube and you'll find it. He is a medical courier, the only major thing he replaced besides oil changes, batteries, and brakes was his alternator.
2003 Echo - Auto Trans - 93,000 mi.
dorman68 is offline   Reply With Quote
Old 11-03-2009, 01:00 AM   #17
Yaris Hilton
Smile
He's right here on this board, and has a long thread about it right here in this forum.
Old 11-03-2009, 08:06 AM   #18
dorman68
Drives: Corolla
Here is the link to the 300k plus yaris. And I was wrong about his brakes, he still has the originals.
http://www.yarisworld.com/forums/sho...highlight=300k
Engine beautification for those show car yaris out there YarisSedan Cosmetic Modifications (Exterior/Interior) 7 09-30-2009 11:18 PM
Has anyone put in a different engine for the Yaris? marlondog Performance Modifications 7 04-14-2009 06:03 PM
Is your Yaris 1.5 Engine noisy? Yawesh General Yaris / Vitz Discussion 49 04-13-2009 12:25 PM
