Old 02-07-2010, 05:59 PM   #1
Former_Neon
Drives: 1997 Yaris LE
Accidentally drove over curb
Last night, I accidentally drove over a curb (about 5" high) as I pulled into a gas station. The curb juts out into the lot and that's where I encountered it. It didn't scrape the bottom of the bumper or anything, however it did dent that black plastic thing that's bolted to the underside of the front of the car (I have no idea what it's called). If I knew how to attach pictures here, I'd show you.
I'm worried that I might have damaged my Yaris.
I probably hit the curb at about 15-20 km/h. There are no marks on the tires or rim that I can see. There are no leaks either. I just took my car onto the highway today for a quick test-drive and, at 120 km/h (75 mph), there is no shaking or shimmying. The car pulls very, very slightly to the left at high speed, but I don't know if it was like that before or not.
From kneeling down and looking beneath the car, I can't discern anything having been bent (other than the hard, black plastic thing I mentioned).
Do you think I lucked out and it's okay?
Former_Neon is offline   Reply With Quote
Old 02-07-2010, 07:05 PM   #2
YAR1S
YAR1S's Avatar
the engine tray or cover or whatever? shouldnt be a problem.... you should get a metal one from garm to replace it :)
-Jen <3
Old 02-07-2010, 07:11 PM   #3
Former_Neon
I figured out how this thing works. The first picture is under the right, front corner of the car (you can see the dent). The second one is of the left, front corner for comparison (no dent). The third picture is of the front, right wheel well (you can see the black, plastic piece out of alignment). The fourth picture is of the front, left wheel well where all is fine.
All those white spots are salt (for those of you who live in the South). They're not scrapes.
Old 02-07-2010, 07:24 PM   #4
ctrj
Drives: 07 Yaris Sdn, 97 4Runner
It looks fine. The large, black plastic piece is called the engine under cover.
RJ
2007 Toyota Yaris Base Sedan -5 speed
SOLD
ctrj is offline   Reply With Quote
Old 02-07-2010, 07:31 PM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
That dent will just pop out if you push or pull down around it .
and be just like new
Old 02-07-2010, 08:28 PM   #6
Former_Neon
Thanks for your replies. I think I'll have to use my ratchet to unbolt the engine under cover on that side & realign it. In picture 1, on the right side, just behind that bolt, you can see it's not flat like it should be. It's bunched between two bolts there for some reason.
I'll get at it once the weather warms a little. It's freezing today.
Old 02-07-2010, 09:00 PM   #7
auxmike
auxmike's Avatar
Your driver's side fender liner is sticking out. It should'nt be.
Old 02-07-2010, 09:15 PM   #8
Former_Neon
Isn't that connected to the engine under cover?
Old 02-07-2010, 09:30 PM   #9
auxmike
auxmike's Avatar
I think that's correct.
The bump may have shifted and pushed up the fender liner from under the sheetmetal.
It's not a tough fix....
Old 02-07-2010, 09:34 PM   #10
Former_Neon
Thanks for the info. And thanks for taking the time to address my issue. Very much appreciated!
Old 02-07-2010, 09:39 PM   #11
auxmike
auxmike's Avatar
Old 02-07-2010, 11:50 PM   #12
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
You need to get your wheel alignment checked.
Old 02-08-2010, 12:04 AM   #13
Former_Neon
Do you think I should, despite the fact the car is not drifting?
Old 02-08-2010, 12:19 AM   #14
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
I'd worry more about all the road salt corroding the steel parts.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 02-08-2010, 12:34 AM   #15
Former_Neon
Little can be done about that, when the roads are covered with it.
I'm not going to wash the car down when it's -10 out.
Old 02-08-2010, 10:52 AM   #16
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
for soem reason yaris' can take curbs no problem, i jumped a curb doing about 35-40 mph and i have no damage, and my car is lowered with rims, no damage at all +D
Aothachos is offline   Reply With Quote
Old 02-08-2010, 11:17 AM   #17
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
hope you dont get a leaking shocks....
Old 02-08-2010, 02:49 PM   #18
Former_Neon
I did a visual inspection under the car (as far as I could get without a jack or a hoist) and everything is dry.
Got hit at work today, lady drove off. Prohibit General Yaris / Vitz Discussion 41 11-05-2009 12:38 AM
Drove in tar! Cutie Pie #2 Wash, Wax, Detailing, Exterior Repairs 18 10-13-2009 03:45 AM
Drove home from work with a damaged belt and... AznGouki DIY / Maintenance / Service 44 09-07-2009 03:08 AM
Test drove Fit, Versa and Yaris... Bought a Yaris! AlexK General Yaris / Vitz Discussion 49 09-10-2007 06:35 PM
I finally test drove a Yaris Hatch... ECHOKnight2000 New YARIS Purchase Forum 10 02-01-2007 01:18 PM
