Old 12-01-2008, 07:47 PM   #1
alfmoonspace
aka "08Yari"
alfmoonspace's Avatar
Drives: 2007 2dr white yaris
Send a message via AIM to alfmoonspace
Exclamation blown axle seal !
My white stalion only has 15k on it and it has a blown seal. I am worried that this is not the only issue with the car even though the dealer is going to fix the seal? Should I be worried? I am in Utah where the winters are hard and I have a long commute, so insights are welcome!
alfmoonspace is offline   Reply With Quote
Old 12-01-2008, 08:28 PM   #2
pinoypizzaboy
Drives: 08 toyota yaris LB
just take it to the dealer they should fix it if its under warranty. or go to a car store and buy a new clamp and grease. be sure to grease the inside of the boot if you do it yourself.
pinoypizzaboy is offline   Reply With Quote
Old 12-01-2008, 08:49 PM   #3
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
how did the seal blow? that doesn't make much sense, they aren't under pressure, maybe it was faulty from the very beginning I don't know... maybe a little more info would help, how did it happen? what were you doing when you noticed it?
turboyaris is offline   Reply With Quote
Old 12-01-2008, 09:04 PM   #4
alfmoonspace
aka "08Yari"
I notice a leak while I was changing the oil, there is also a crank seal leak that I noticed, scary stuff. I took the car today to the dealer and they said they will have everything fixed by tomorrow. I will let you guys know more details of what they found tomorrow. Thanks
Old 12-01-2008, 09:25 PM   #5
i dont see why you'd have to pay for anything while youre still in bumper-bumper warranty...
i had lots of stuff go sideways in my old matrix, but it was all covered...
Old 12-01-2008, 10:40 PM   #6
auxmike
auxmike's Avatar
Would you need to prove you did proper oil changes, etc. in this case to avoid a hard time from the dealer?
Old 12-02-2008, 02:05 AM   #7
YarisSedan
Drives: 08 Yaris Sedan
How much oil are you putting in your car. Too much oil leads to excessive crankcase pressure resulting into blown seals. Such as cam, crank, valve cover and oil pan gaskets. Whichever is the weakest first blows to relieve the pressure.
That or your pcv valve is clogged. I would reccomend removing it and seeing if it rattles and cleaning it with some carb cleaner. Or just simply replacing it they are cheap. I always replace my every 2 years. Along with my radiator cap. Very cheap and easy to fail items. That could save you hundreds if not thousands down the road.
Old 12-02-2008, 06:33 AM   #8
you did say axle seal, right? wouldnt that have nothing to do with whether or not you put oil in your engine?
Old 12-02-2008, 02:45 PM   #9
YarisSedan
I was reffering to the oil seal portion of his post.
Old 12-02-2008, 02:50 PM   #10
i realize, but im just not sure why he asked this:
Old 12-02-2008, 04:45 PM   #11
alfmoonspace
aka "08Yari"
3.7 liters (think that is how much the manual says), I am extremely careful when I change the oil (always mobile one), at least I hope I am... Do you think that this could be the only problem, or is there an underlining issue that needs to be addressed?
Thanks for your comments though!
Old 12-02-2008, 05:31 PM   #12
alfmoonspace
aka "08Yari"
Ok, so the dealership guy just called and mention that it is only one issue. It is where the axle is connected to the transmission, which it has been leaking everywhere. It will be fix by tomorrow!
Keep you guys updated...
Old 12-02-2008, 08:22 PM   #13
auxmike
auxmike's Avatar
Stick or auto??
I had an axel seal leak soon after a clutch job on my Satty. What a hot , smokey, smelly mess it made!
Old 12-02-2008, 10:42 PM   #14
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I had that same problem at 13k... Happened after I hit a dip on a gravel road really hard (I didn't see the dip until the last second).
7,000 miles later I still have no problems. I was worried that the alignment may be off, but I've got no abnormal tread wear.
If you've hit a similarly hard bump recently then I'd check the alignment, but wouldn't worry unless the mechanics says something is haywire when you have your oil changed, or you start hearing noises.
Old 10-13-2009, 11:09 AM   #15
CKaelin
CKaelin's Avatar
Drives: 2008 Yaris LB 5 speed
I have an 08 LB with 20,000 miles. Just got an oil change and while it was up on the lift the mechanic pointed out I have an axle seal leak aswell. I am taking it in to the dealer tomorrow. Think it will be covered under warranty?
My other ride's a Gixxer!
CKaelin is offline   Reply With Quote
Old 10-13-2009, 12:20 PM   #16
auxmike
auxmike's Avatar
That's just plain awful. What ever happened to "Toyota quality"?
Hope the yaris does'nt turn into the next Yugo...
Old 10-13-2009, 12:55 PM   #17
Lafiro
Drives: 06 Yaris Sedan
Yes, so you guys found these problems, others are finding other problems like me and lots of others with the 07 yaris.
Now I see never to make the mistake again of buying a first year model, or for that matter, this inexpensive of a car period :/
Other then that, its a great car.
Old 10-13-2009, 01:27 PM   #18
CKaelin
CKaelin's Avatar
I love the car don't get me wrong! 40+mpgs and it's paid for! I just hope it's covered under warranty. I'll let you know as soon as I find out for sure.
leaky seal on engine? oil overfill? jeff69dini DIY / Maintenance / Service 23 06-07-2010 01:52 AM
Looking for GTA HB to test Axle Back System RaptorRacing Canada 8 11-29-2008 12:14 AM
FS: Tanabe Concept G axle back exhaust yrsdrgn Items for Sale by private party 9 08-20-2007 05:33 AM
wtb 1nzfe engine blown or working turboyaris Items for Sale by private party 5 04-08-2007 03:03 PM
yaris takes a blown tire really well dbaxter General Yaris / Vitz Discussion 4 11-28-2006 05:14 PM
