Old 11-24-2009, 02:17 AM   #1
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
F/S Voltage Stabilizer with LED display
Hi people i have one of these for sale
brand new never used , looking for $60.00US Shipped
well below cost , but due to some unforseen medical bills
it must be sold .
1NZYaris1 is offline
Old 11-24-2009, 06:43 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
just a quick blurb about the stabilizer ,
anyone keen to give it a try.
Violence Super Stabilizer
Next Generation Fine-Tuning Upgrade Add-on
( Specifically Designed to Handle Extreme Power Variances )
Professional ‘Grade 12.6-16.8v Electrical Stabilizing Unit
(Domestic/Import, "Loaded" Models, Luxury, Exotics)
(Light, Medium, Heavy Duty Trucks, SUV’s, Hummers)
A Must-Have for Over-Accessorized Electrical Systems
Increased Torque, Throttle Response and Power
Extended Battery Lifespan
Improved Fuel Economy
Enhanced Audio Quality
Premium Light Output
Reduced Emissions
3 - Direct Connect Cables with Stainless Steel Braided Jacket
INCLUDED
Additional "Cut-to-Length" 4 awg Cables
with pre-installed 5/16” Commercial Ring Terminals
Old 11-25-2009, 03:41 AM   #3
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
I can't find much online about them. Is there some online directions for the stabilizer that i can look at, or does it come with some. I would like to see/hear/know more about it...
kac is offline
Old 11-25-2009, 05:52 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
If you are wanting install instructions yes i am pretty sure it comes with them.
Not really sure what you want to know , as i dont know much about them my self (still reading about and learnning ) , and as i am awaiting its arrival ,
with my Throttle Control units .Which where do today accordding to my tracking number , but thats another story.
Does it work on the Yaris , well that again depends on
who you ask , a lot of JDM people in the Asain Countries swear by them .
Below is a comment pulled of Tundra Sollutions .I will copy the instructions and what not tomorrow when it arrives , and post them here
Theoretically, it should help to stabilize the voltage of a power supply. This is big in the audio field for improving sound quality. The two big "ifs" here, are 1) whether a particular product actually does ANYTHING to stablize the voltage (lots of empty box "miracles" in the audio world...) and 2) whether the engine computer etc. can be improved with a stabilized voltage. If the ECU has been designed properly, slight variations should remain insignificant.
So, to answer your question, it "depends." First you'd have to test the product to see if it really stabilized anything and then you would need to see if it actually improved some parameter on a specific model ECU. Thus, it is possible that on a 4cyl Escort, it might make a huge difference while on an 8cyl Tundra there is no noticeable improvement.
The ultimate question to ask the manufacturer or retailer is "does this product significantly improve some aspect of a 2002 toyota tundra 8cyl?" If they claim it improves ALL systems, I would be wary. Be sure to separate the answer of "yes, it stabilizes all voltages in all makes" from an answer that states "yes, there is improvement in some aspect (gas mileage, etc.) on ALL models." The first reply could always hold true to some degree, while the second response is just not plausible because of the many different ECU designs.
i hope that has help .
Old 11-26-2009, 09:54 PM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
basic and very simple instal instructions
it also comes with a bonnet switch to turn off the LED display
when the bonnet is closed
Old 11-27-2009, 05:46 PM   #6
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Is there any interest
looking for some one indipent to try it out and give honest feed back .
or should i just put it on mine.
Old 11-27-2009, 08:48 PM   #7
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Info supplied by Manufacturer
How This Item Works:
The vehicle's ECU is highly dependant on all sensors that provide data and signals to coordinate different parts in different places of your vehicle. The vehicle's ECU can analyze if the voltage flow on your vehicle is accurate. What this does is enhance the voltage and stabilize it, so all the components in your vehicle such as audio, lamps, sensors and electronics work to their maximum potential. By stabilizing the voltage from the battery of your vehicle, the load of the battery is reduced, resulting in increasing engine performance.
Old 12-09-2009, 01:42 AM   #8
YarisSedan
Drives: 08 Yaris Sedan
Violence.... power heavy weapon.... high technology....
YarisSedan is offline
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Shift Knob with LED Gear indicator Ferret_san Cosmetic Modifications (Exterior/Interior) 8 09-30-2007 12:06 AM
Car Voltage Stabilizer + Earth Wires Grounding Cables Are they any good ? Julz General Yaris / Vitz Discussion 4 09-03-2007 03:13 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 02:01 PM
