Old 10-20-2009, 10:54 PM   #1
webfeet69
Drives: 2007 yaris 3 door
2007 3 door 350000 miles eats wheel bearings!
hears all the info i know,
The car is my father in laws owned since new. the car is used for package delivery hence the milage. by the way the car doesnt use any oil and he hasnt had any problems until this big problem. He started hearing a growl and found the rt front bearing was bad. replaced the bearing and he still had some noise. they then found the trans main bearings were worn and put in a used trans. all was well for 300 miles! same bearing went bad again! he has since put 5 wheel bearings in the car. he has tried just the bearing itself, new bearing from toyota, totaly new hub assembly from toyota. He just called from lee mass and said bearing is making noise again. 280 miles this time! Any ideas? the only thing i can think of to check when i get the car this weekend is all trans and motor mounts. i am thinking that if the mounts are shot then its possible the engine moved putting side tension on the bearing causing the failures. the car has never been wrecked or damaged.
Thanks in advance,Todd
webfeet69 is offline   Reply With Quote
Old 10-21-2009, 12:00 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Wait.. he doesn't use OIL?
Old 10-21-2009, 12:29 AM   #3
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
those mechanics are idiots.
find a new place to service the vehicle
127.0.0.1 is offline   Reply With Quote
Old 10-24-2009, 09:17 PM   #4
webfeet69
real answers please!!
thanks for your input and stating the obvious but i need a master tech's input please!
Thanx
Old 10-24-2009, 10:32 PM   #5
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Thanx
Since wheel bearings are pretty reliable, repeated failures are likely due to some factor outside the bearings themselves - a bent spindle? - maybe faulty installation - over-tightening the spindle nut, leaving out a spacer, something like that.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 10-24-2009, 11:06 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
+1
Old 10-25-2009, 12:02 AM   #7
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
I would start looking for a replacement. You obviously got a bad Yaris!
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 10-25-2009, 01:20 AM   #8
Kal-El
Kal-El's Avatar
Wait! There's anther 350,000+ mile '07 Yaris in existence??
To the OP, there's a member here with a sedan over that mileage. He was thought to be the only human to drive that much.
If you could get up any pics (odometer pics too) and more info about the car it would be great!
Old 10-25-2009, 12:57 PM   #9
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
i have a getting loader whine on very smoth roads have not looked into it much but it does run with the speed of the car . im hoping it not the wheel bearing but till it really gets worse hard to tell exactly what it is and i have 58000 miles and im sure toyoya would call that a wear item so they will not take of it i bet anybody that has any thing that sounds like this problem please give me a heads up i know cars pretty well i could put the car up on jack stands and run it and see what i get kinda sketchy but i need to find this noise its driving me crazy
pennyracer is offline   Reply With Quote
Old 10-29-2009, 01:10 AM   #10
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
Wait! There's another Yaris out there with as much miles as mine? WOW! This is great news for Yaris owners out there. Just goes to show the reliability of this little car. Bottoms Up!!!
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 10-29-2009, 12:58 PM   #11
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
sorry for coming off topic but, the amount of miles you have on your yaris (and continue to add to) never ceases to amaze me
Old 11-01-2009, 12:36 AM   #12
Dans08
Drives: 2008 LB
I've seen on Hondas where the knuckle is out of round and that distorts the bering when it is pressed in. Dan
Dans08 is offline   Reply With Quote
Old 10-29-2009, 01:33 AM   #13
YarisSedan
Drives: 08 Yaris Sedan
Probally the mechanic who pressed the bearing installed it incorrectly? The bearings on the yaris are pretty bullet proof. Unless he hit something really really hard to damage it.
Old 11-01-2009, 01:23 AM   #14
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
I'm no expert, but try looking into the wheel or tire. It may be out of round or bent to one side and is causing too much stress and bearing failure.
Old 11-01-2009, 05:28 AM   #15
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Do they still manually pack the bearing with grease before installation if so they may be forgetting the procedure or using the wrong grease ,If its just the one bearing it might be prudent to bring it to the dealer to have it done according to factory specs.
Old 11-01-2009, 06:10 PM   #16
2+2
Drives: 09 3Dr Manual
I almost made this same post earlier today. The only thing that stopped me is how quickly the bearings are getting killed.
Good luck with it!
Just put the pedal down and let the devil take the hindquarters.
2+2 is offline   Reply With Quote
Old 11-01-2009, 07:09 PM   #17
auxmike
auxmike's Avatar
Old 11-06-2009, 07:55 PM   #18
2+2
Bad batch of bearings? Do they put lot numbers on replacement wheel bearings?
Any news op?
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 10:54 PM
2007 Yaris liftback, Philly suburbs, red auto, loaded, 30K miles, w/ trailer hitch carlgt1 Cars for Sale by private party 11 07-10-2009 12:12 PM
forged rims Vs. alloys red-jdm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 07-23-2007 09:30 PM
