Old 12-23-2009, 01:47 AM   #1
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
Brake question
I searched but didn't find anything. Are the sedan and hatch brakes the same in the front? Even the same as the Vitz? Brackets and everything? I only ask because I have been offered a deal on some endless calipers and rotors but they are for the vitz. If they are the same, I plan on picking up a set. They are for performance, but I also want them for the color.
Old 12-23-2009, 01:50 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
I cant say for 100 percent certain but most likely so. Easiest way to check is measure the distance between the bolt holes and as the person whos selling them to you to check and see if its the same.
Old 12-23-2009, 01:59 AM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
If you are talking about Yaris/Vitz 2006+ Verse's Sedan 2006+ then yes they are the same (depending on if they are stock or aftermart )
As aftermarket goes upto 302mm DIA and stock is 255.mm dia
if you are talking about the echo/vitz then no they are not the same
the Echo has thinner calipers and a different offset .
Old 12-23-2009, 11:47 PM   #4
RHDVIPbB
Well thanks for the response. I was finally able to get on Endless site and this is what I plan on getting.
http://www.endlessusa.com/brakecaliper/4-pot/
Old 12-24-2009, 09:31 AM   #5
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
Very nice
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
Brake question xen555 DIY / Maintenance / Service 8 03-06-2009 06:14 PM
Help Needed - Brake Light Question *MAD DOG* Cosmetic Modifications (Exterior/Interior) 21 02-08-2009 06:32 AM
Yaris/Echo Rear Brake Question pdarnell DIY / Maintenance / Service 2 08-21-2007 02:15 PM
