![]() ![]() Drives: Yaris Join Date: Oct 2006
Do I need to switch N position when waiting for Traffic Light?
I just wonder if switching the transmission position to N when waiting for the traffic light can use less fuel than I press Brake Pedal and hold on D position
THX |
#2 | |
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
A moot point. IMHO, whatever you choose to do, the effect on the fuel economy will be minimal.
If the wait is short, I prefer to stay in the 'D' position. In case of emergency, I can just step on the gas and go without delay. In the case of a long delay, say for example, when an accident holds up the traffic and it is known that I will have to stop for quite a while, I will shift to the 'P' position so that my foot does not have to step on the brake for too long (note: on a steep slop, any long stop will call for the use of the hand brake in addition to anything else). Fatigue and loss of concentration can cause mishaps. |
![]() ![]() Drives: 07 Yaris LB, 06 VW GTI, 06 G6 Join Date: Aug 2006
No.
#5 | |
+1 |
![]() ![]() ![]() ![]() Drives: 2007 Black Yaris sedan Join Date: Sep 2006
It could even wear out the transmission faster,I never put it in neutral.
![]() ![]() ![]() ![]() Drives: 2007 Yaris S Join Date: May 2006
motor will also rev higher when in neutral ;) not saying it really uses more gas to do so, but thats what it does :)
Small Car Lover
I always put my car in neutral (I have an auto), I thought it was better for that. I only put it in if I know I will be waiting for awhile...but I usually have my hand on the shifter in case I have to put it in drive fast but I make sure I don't step on the gas too early while shifting and what not cause I know that's hard on an automactic.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
It does not hurt the trans to shift to neutral while waiting for extended amounts of time. But it's not needed for short stop light stops. Just keep it in drive unless your going to be sitting for a while.
I shift to neutral while sitting at the CAN/US border crossings for 20-40 minutes because it's easier on the transmission. Think about it, when you take your foot off the brake it will move ahead without touching the accelerator, thats because there is drag between the clutches in the transmission. Holding it there in drive for extended amounts of time causes the clutches to slip constantly creating heat and wear on the clutches and breaks down the oil quickly. When you shift to neutral it allows the main and secondary shafts to spin freely at matched speeds with no load so you eliminate the slipping. But no you don't need to and no it's won't really make a difference on the fuel economy shifting at short stops.
The early bird gets the worm, but the second mouse gets the cheese. |
07WYarisRS, I thought the torque converter ("clutch") on an automatic transmission used the drag of a viscous fluid to cause the transmission side of the device to spin? Thus on D at low revs, all you are doing is spinning this fluid around, which would put some resistance on the engine, but it sould not wear anything out?
Or am I wrong and the Yaris auto transmission is using a clutch system like a manual one?
HardlyDangerous
BOTH
Automatics transmissions do not use a primary engagement/disengagement clutch like a manual trans does but they do use clutches. With a manual trans you have a single clutch on the flywheel and inside the manual transmission is sets of gears, input and output shafts with syncros to switch gears With an automatic you have a torque convertor on the flywheel is basically a centrifugal hydraulic pump witch acts like an automatic clutch as well as a high pressure pump to puch fluid to the clutches. But inside an automatic transmission is several sets of clutches and electronic valve body and bands that control the input to the main Planitary gearset. An automatic trans uses the pressurized fluid through the valve body to engage and disengage the clutches for each gear. When idling the pressure is low and it applies less pressure to the clutches to keep the car from moving. As you step on the gas the pressure builds up more and forces the clutches to engauge. When you shift to neutral the valve body closes the piston that and redirects the fluid removeing pressure from the clutch. All that being said the car is designed to sit at a stop in gear not moving. but like I said shifting to neutral will not hurt and can add a bit of life to the clutches and fluid over time. I usually don't recommend it because so many people don't take the time to shift slowly. Just like when people are backing up and slip it into drive while still rolling backwards. That tears up the clutches. When shifting from park to drive or neutral to drive the shift must be complete with a second or two pause before stompin' on the gas. This allows the fluid do it's job and eliminate clutch damage. check this out for more MUCH more detailed pics and information http://auto.howstuffworks.com/automa...ansmission.htm and a pic of a Yaris transmission apart. at the back of the bench(middle) is the clutch packs
The early bird gets the worm, but the second mouse gets the cheese. Last edited by 07WYarisRS; 11-10-2006 at 02:16 PM. |
#12 | |
![]() ![]() ![]() Drives: Yaris 3dr Hatchback Join Date: Oct 2006
HUM, what do you mean it is designed to sit at a stop and not move? even if im on an uphill incline not moving if i let go of the break it will slowly start popping and driving forward up the hill. Def. cant let go of the break when im flat on the ground! so what do you mean by sit at a stop in gear not moving? in D and not move forward?
HardlyDangerous
I meant you don't have to shift to neutral or park when you stop at a light ot intersection or what ever.
keep your foot on the brake and the transmission in drive. The transmission was desinged to be kept in drive with no need to shift out of drive to neutral when stopping briefly. You can...it won't hurt it, but doing so is not necessary. There is normal wear that will be accelerated buy constantly shifting at stop lights that you may otherwise never incounter.
#14 | |
Small Car Lover
HardlyDangerous
When backing up come to a complete stop, then shift to drive. i don't even recommend shifting to neutral while rolling back wards.
When you do shift to drive make sure the car is at a complete stop then when you feel the car put load onto the engine and then you know it's safe to go. This takes a second or less but doing so the transmission will last the lifetime of the car. Jumpin back and forth even with the car rolling a little bit or jumpin' the gun kills the transmissions and is why so many people think auto trans are not relaible. They are used improperly and abused.
![]() ![]() Drives: Yaris Sedan Join Date: Aug 2006
So I've heard many people here with the 5-speed talk about how they put it in neutral all the time to save on gas.. For example, going down hill, or long before a stop sign so you slow down like that. Is this bad for the car?
#17 | |
50% borikén
Drives: 06 Mazda5, 90 240sx Join Date: Nov 2006
not bad for the car, BUT, you only have the brakes to reply on, no engine braking, so down a long hill this may cause the brakes to fade, or in an emergency, it's always good to also ahve the engine brake to rely on.
Still, that feeling of just floating down hill silently is hard to beat!
