![]() ![]() ![]() Drives: 2017 L 3-door Join Date: Mar 2011
185/60r15 on steelies VS. 175/65r14 on steelies...
Looking to replace current tires (185/60r15 on steelies). As an alternative to just replacing the tires, I'm considering getting tires/steelies from tirerack, since it's a nominal amount more for the set. The downside is they only have 14 inch steelies.
Would moving from a 185/60r15 to a 175/65r14 have any impact on fuel economy, and if so, to what extent? I realize the smaller wheels are about 3% smaller in diameter so if they improve fuel economy is it a result of the speedometer reading faster than actual travel or is it a true improvement in spite of this? |
The tire width (i.e. reduced friction) would be the thing that would help with fuel economy (minimally {1-2 MPGs max} between 175 and 185). The 175s would rotate 3.3% more than the 185s, so your speedometer would be off by that much between the two.
I believe that 14" setups are typically a bit lighter than 15" setups, so you would notice a bit better acceleration (as well as the smaller diameter would also help this, but would reduce your top end / would mean higher RPMs for same vehicle speed).
| 14 inch widen steelies with 40mm drop? | Rednaz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-02-2014 04:00 PM |
| Dunlop Graspic DS-3 winter 185/60R15 90% left | 07yaris_fe | Items for Sale by private party | 0 | 05-28-2013 10:31 AM |
| WTB (2) steelies and (4) hubcaps | dean_park | Willing to Buy by private party | 6 | 03-24-2011 10:26 AM |
| Boredom and 4 cans of paint=ghetto steelies | contraband831 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 11-18-2010 04:40 PM |
| FS: 4-15" Steelies and Hubcaps $100 | MGargano | Items for Sale by private party | 11 | 08-19-2009 10:22 PM |
