Old 07-13-2015, 04:15 AM   #1
Girishk19
Drives: Toyota Belta
Noise when accelerating on slope
Hi Guys,
Really need help.
There is a noise coming from the front of the car whenever i accelerate on slopes and no noise when am doing a descent except if i pump the gas pedal too abruptly. I have replaced the timing belt but the noise still persists and it is becoming quite noisy.
There is no problem as such with the car but this noise is making me worried. Some people have said that this is a recurrent problem in the gas pedal.
No mechanic has been able to diagnose this problem and keep telling me to change parts and have already done some changes with no result.
Can anyone please help me in trying to diagnose this issue.
Thanks
Girishk19 is offline   Reply With Quote
Old 07-13-2015, 09:36 AM   #2
What kind of noise? Grind, squeak, clatter, tap? There are just so many different types of noises a car can produce. Help us out here so that we can hopefully help you.
Old 07-13-2015, 03:44 PM   #3
tmontague
tmontague's Avatar
Agreed w/ what Yari said above.
You mentioned you changed the timing belt...i'm assuming you meant the belt attached to the alternator as the Yaris has a timing chain, not a belt.
If it is a squeal coming from the belt then re tension it
Old 08-05-2015, 01:22 AM   #4
Girishk19
hi Guys
its the same problem as Mikastef
See Thread for more details: http://www.yarisworld.com/forums/showthread.php?t=54069
Cause of growling noise when accelerating? xorrbit DIY / Maintenance / Service 4 09-02-2015 12:05 PM
metallic noise when accelerating poida DIY / Maintenance / Service 3 03-29-2015 01:20 AM
Whirring Noise when accelerating RatedRVD DIY / Maintenance / Service 11 06-06-2012 01:07 PM
drivetrain is making funny noise while accelerating whoknows89 DIY / Maintenance / Service 0 02-09-2012 05:28 PM
Strange Noise when accelerating! cybertees DIY / Maintenance / Service 22 05-24-2009 09:37 PM
