Old 06-21-2010, 12:58 AM   #1
Liu997
Drives: 2008 Red Yaris LB
rear brake drum leak
I found a leak today in the drums so I disassembled everything and found a small cut on the wheel cylinder boot. the little rubber thingy. Where can I buy one? The only thing i found was the whole assembly on sale at advanced
Liu997 is offline   Reply With Quote
Old 06-21-2010, 05:49 PM   #2
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
You should be able to buy a replacement slave cylinder for it, both genuine and aftermarket.
rob323 is offline   Reply With Quote
Old 06-21-2010, 08:30 PM   #3
RedRide
RedRide's Avatar
The "boot' is just a "dust cover".
If it's leaking you have a leak internally from the pistion and need to either rebuild the cylinder (if they still sell rebuild kits) or get a new one.
Old 06-21-2010, 08:57 PM   #4
yarrr
Drives: 07 sedan
Agree with redride. The whole cylinder should only be like 20-30 bucks. Tell whoever did your rear brakes last to be more careful next time.
yarrr is offline   Reply With Quote
Old 06-21-2010, 10:05 PM   #5
Liu997
thanks guys will do
Old 06-21-2010, 10:57 PM   #6
severous01
it's more trouble than it's worth to rebuild. plus, if you do one you gotta do the other due to size differences in the bore diameters causing differences in pressure drops on the drums.
any way, just get a new one.
Old 06-26-2010, 07:13 PM   #7
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
New will save you some time.
frog13 is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 07:05 PM
Removing drum from rear axle bankrobber DIY / Maintenance / Service 20 07-01-2010 05:24 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
