Old 12-21-2009, 09:26 PM   #1
hyprmiler
It's cold in Wisconsin...
Drives: 2008 and 2009 Yaris Sedans
Just ordered my Scangauge II
I'll have my scangage in tomorrow. =) Free overnight shipping is amazing. =)
I can't wait to see what kind of numbers I'll be pulling.
hyprmiler is offline   Reply With Quote
Old 12-21-2009, 09:39 PM   #2
Aww, didn't support a supporting vendor?
you'll like the Scangauge, it's easy to read and very useful.
Old 12-21-2009, 09:42 PM   #3
hyprmiler
Sorry didn't go with the local vendor this time.
Next time though.
Old 12-21-2009, 09:47 PM   #4
hyprmiler
Do you guys sell any of the quick drain oil plugs? Or are those gimmicky?
Old 12-21-2009, 10:12 PM   #5
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
they may be gimmicky. regular plug cannot fail, those might and sometimes do. is engine damage worth the time saved ?
127.0.0.1 is offline   Reply With Quote
Old 12-22-2009, 02:48 AM   #6
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Fumoto FTW.
Old 12-22-2009, 05:57 AM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
After you get used to the gauge a bit you might want to set the X gauge to show average mpg as the real time mpg reading is all over the place..
X gauges are a bit of a cluster f--- to set up but the average mpg setup goes like this=
From the home screen ( button with red around it ), hit more>more>more>xgauge
Now you can select the memory slot. If its already on 0 and this is the first xgauge you are creating, go ahead and hit the edit button.
You should now be at the TXD screen
Use the + and - buttons on the left side so that the first number is 0 Then use the arrow button on the right side to move over one space Now it depends on what trip function you want to use..
use the + or - again to adjust
0 - for current trip which resets every time you start the vehicle
1 - for today trip which resets after 10 hours of ignition off time
2- for previous day
4- for tank trip
on mine I have 01 for average fuel economy today
next hit the OK button
You should now be at the RXF screen
use the + or - buttons until the first digit is 8.
Then push OK button 3 times until you get to the name screen
Here you can pick any three letters to name your gauge.
I used AFT for average fuel today
Then hit save
Now you can go back to the home screen and hit gauge. Select which of the four spot you want the gauge to appear and hit the button until see the three letters that you just used to name your gauge.
Old 12-22-2009, 09:41 AM   #8
hyprmiler
mind if I ask where ya'll mounted yours?
Old 12-22-2009, 01:49 PM   #9
when i had one, i put it right in front of me on the steering column.
Old 12-22-2009, 10:51 PM   #10
hyprmiler
So I got it in the mail today, and so far I love it.
Still need to mess around with it and get it fully programmed. I think I'm going to zip tie / mount it to my GPS unit.
So far it seems to be fairly accurate when it comes to usage, I just need to get it calibrated and fully set before I trust it any further (not to mention do some math to make sure it's not sweet talking me).
Old 12-23-2009, 12:20 AM   #11
127.0.0.1
if you fill up using the exact same gas pump, parked the exact same way, and stop at the first
click every time, it cannot do anything but calibrate itself correctly over 2 or 3 tanks. this may vary.
preprogram it for a 2.9 offset and it'll be really close to perfect
(given you do the initial setup properly)
Old 12-23-2009, 12:55 PM   #12
hyprmiler
out of curiosity... why 2.9 offset?
Old 12-23-2009, 02:08 PM   #13
127.0.0.1
because that is what my offset ended up to be and
2.9 will probably get you accurate mileage from the first tank
you can choose not to set it, and it'll take 3 or 4 tanks to
be sure the offset is accurate. 'cuz your first two tanks will be
off, and leave you wondering. you'll prob end up at 2.9 or 3.2
anyhow if you have a 1.5 liter yaris
Old 12-23-2009, 09:33 PM   #14
hyprmiler
I just can't find a good place to mount this damn thing....
I think I'm going to try and fasten it to the bottom of my GPS mount. That's tomorrow's task.
Old 12-24-2009, 11:52 AM   #15
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
I popped off my A-pillar trim and ran it up there, under the headliner, and mounted it on top of the rear-view mirror. Not a bad spot for it... although a bit hard to read when it's bright out due to contrast.
2006 Red Blitzed RS 5-door
Old 12-24-2009, 01:18 PM   #16
127.0.0.1
put mine right on the steering wheel hump in front of the storage bin
shoe-goo and velcro strip. cable up the back side. looks like it belongs there
Old 12-25-2009, 10:40 AM   #17
hyprmiler
I don't trust this thing till it's calibrated... but I'm averaging 30-42mpg on the highway on trips.
I set the 11gallon tank
I set the 1.5 Liter engine
The only puzzling thing for me was when I did a full fillup it asked me to cycle though (very slowly I might add) how much I put in the car. I assume I don't touch that and leave it at zero? The quick reference guide wasn't very helpful or specific on that.
Old 12-25-2009, 10:46 AM   #18
127.0.0.1
you tell it how much gas you put in
if it's estimate is exact and shows what you put in, don't touch it
if it is off, adjust it by what you actually put in
then put in the cost
it is all in the user manual
Official Scangauge II Thread - Share your Data, Discuss Settings ,Problems, Findings! TRD_Yaris General Yaris / Vitz Discussion 183 02-01-2017 12:18 PM
BDD's first mods - tach + Scangauge II BDD Performance Modifications 11 04-29-2013 11:23 AM
What is the average Scangauge II offset percentage ? 127.0.0.1 Fuel Economy Forum 13 03-05-2010 08:08 PM
scangauge II versions TinyGiant Fuel Economy Forum 1 12-23-2008 12:10 PM
Ordered mine today... now the wait begins boris13 New YARIS Purchase Forum 1 11-10-2006 07:40 PM
