Would It Be Possible?
I would like to use twp these: http://www.v-leds.com/Interior-LED/D...74230-1-3.html
for footwell lighting in my sedan. Is it possible to just splice into the dome light wire, or would there be something else needed to be done? I'm also planning on sticking the leads into a 194 holder and using it in my trunk as well. That should be no problem, right? |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
You'll need to check the total voltage and load so you won't fry any wires. Best thing to do is to find a different power source like the cigarette lighter and use the dome as a relay to turn on that power.
How easy would that be? TIA.
The checking?...someone with more knowledge about that will hopefully chime in. The wiring?> quite easy, just the extra step of putting in the relay, same wiring and splicing techniques, it just draws power from the other source with input from the dome light.
I would do it for safety sake, more load on something not meant for the extra load spells troubles and headaches for me.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
If I remember correctly, the cigarette lighter only supplys power when the key is turned to accessory or maybe only if the car is on?
I ran into this problem with my ipod not charging while I left my car.... Soooo if you only want them on when the car is running then you wouldnt have to splice them into anything and they would just turn on with the car.... no cool dome effect tho :(
-Jen <3 ![]() Quote:
I think leds take hardly any power. And the dome light circuit is fused so if anything the fuse would blow before any wiring would melt.
They would be fine. If you want them to be switched with the dome and to fade like the dome, see this post from a prior thread:
http://www.yarisworld.com/forums/sho...0&postcount=14 You would tie the (+) lead of the LED strips to the blue wire and the (-) lead to the pink wire. |
#8 | |
#9 | |
If you wanted to be super safe, you would add a fuse between your tap point and the LED strings that is appropriately rated for the current draw of the LEDs and the current carrying capacity of the wires that feed them. 24 AWG wire (which would be typically the smallest wire size for the leads of strips like those) is rated for 2.1A enclosed or 3.5A free-air. The LED strips would draw less than 0.25A per strip, so you could add a 2A inline fuse and be safe for the wire size. The 2A fuse would allow you to connect up to 8 of the strips. When you have a huge discrepancy, like tapping a 50A fused circuit with 24 AWG wire, is where you really run into the issue that talnlnky is talking about. In that case, if you shorted your 24 AWG wires, the 50A fuse would need to pop, but the 24 AWG wires aren't rated for anywhere near 50A, so they would fail before the fuse, potentially catastrophically (i.e. fire). |
#10 | |
#11 | |
Audio Junky
the draw from some LED's will not be an issue in reality... but to get technical, it is always best to use a new run of wire for your power & ground... people every year toast cars because they don't understand about heat & resistance of wires.
You could also replace the dome light bulb with LED that should cut down on the draw on the circuit to help offset the led strips your adding too.
hahaha, replaced my map and dome lights with HiLEDs a long time ago. My trunk has a crappy single LED, so I'm going to remove that LED from the 194 holder, and insert the LED strip I mentioned earlier into it, and use it in my trunk. My license plate bulbs are also HiLEDs as well. hahaha. The only thing short of LEDs is my taillights. hahaha.
Would this work? http://www.v-leds.com/BlinkerWarning...20629-1-3.html
Hey Scott, is it suppose to only turn on when the doors are opened, and don't turn on when the dome light is set to on? That's how mine is acting, and I just installed some LED strips on my gf's Civic, and her's does the same. Any way to have the strips turn on when the dome light is switched to the on position as well as when the doors open?
#17 | |
Dang. I might just get a switch and redo everything. Get the positive to a constant power and place a toggle switch somewhere hidden. I'm thinking this is more than I can do on my own, so I'm going to have a friend help me out this time and learn so that I can redo my gf's Civic. Thanks for replying, Scott.
