![]() ![]() Drives: 07 yaris hatchy Join Date: Sep 2007
I've done lowering springs before, no problems. Well today I lowered my car, finished it all up, and then got in the car and turned the key. Put it in drive and heard *SQRREEEECH* I was like oh no! So I immediatly turned car off. Jacked it up, and my axle was popped out of the transmission. I broke a bearing and it popped out. It was never in the all way. Do I have to buy a whole new axle? Or can I just get that bearing that was on one of the 3 tips of the drive shaft? I'm refering to the shaft that goes into the transmission... Whats that called anyway? Axle or driveshaft? or what? So yeh big mess. Could be extremely costly for me right now
I am not happy with myself. Lowering springs gone wrong! ![]() Last edited by wholenizz; 03-24-2010 at 09:51 PM. |
![]() ![]() ![]() Drives: 2009 Yaris Onyx Join Date: Dec 2009
Am i gonna have to replace the whole shaft? Or can I get the bearing I need?
my guess is a dealer will only sell you a complete half-shaft, check the local yellow pages and see if there anyone who re-builds half-shafts in your area.
cool I am hoping its just a standard size bearing or whatever thats really my only hope. Otherwise I just made a $300 mistake or more :[ I shud have just taken it to the tire place down the street for them to do the springs... I am so pissed at myself.
Team VAJJ
Drives: 2007 Yaris sedan Flint Mica Join Date: Mar 2010
I don't understand why that happened? It's not like those springs would drop the car low enough to put your axle at such an angle that it would snap! I am tucking 14"s on my jetta, and my axles hit the body on occasion due to the car being so low, and I have never trashed an axle like that and you have to consider the angle that my axles are at as well.
I just don't see how a simple spring install could have broke your axle by the hub, which is what it seems like you are saying. It must have been on it's way out already or something. Post pics though, I am interested.. Ps: don't pay for a spring install, save your money, it is so easy and I doubt it was something you did
2007 Yaris Sedan DD, 95 VW Jetta boosted and laid out...stretch and poke FTW |
Drives: yaris sedan Join Date: Mar 2010
Loves to travel
yikes im sorry that happened to you! Hope you can get everything situated and fixed
k ill get pics tommorow. I mean I guess it wasnt in there right. It pulled out when the knucle was loose free to move around detached from the strut. And it must have pulled out and got placed in there all funky.
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
When I put my springs/struts on, the axle got pulled out a bit. I just fussed with it and got it back in.
How do you know you messed up the bearing? (Where in Oregon are you, by the way?)
Subcompact Culture: The Small car blog |
#12 | |
corvallis, OSU. So uh turns out I can't just get the bearing im going to have to find a whole axle... |
![]() ![]() ![]() Drives: 2007 and 2008 MM Yari LBs Join Date: Aug 2006
I have seen a axle pop out before but we managed to get it back in. PITA. I would call your dealership and see what they say first than call around to a few shops to see what they say. Calling doesn't mean you have to pay for it.
Always a recommendation that you could have used before this all went down. Keep your axle straight when removing the suspension. Place something/anything under the arm to keep it straight while toying around with the coil overs. Edit: I don't think you will have to replace the whole shaft. Hell unless you are absolutely certain this cause a bunch of damage, I would probably see if I could get the shaft back in and see if it would drive, so that you can take it to a shop at least to have a professional look at it. That is unless your nearest shop is more than 50 miles away. Otherwise you may want to have it towed.
Two Yari on home! ![]() |
#14 |
I have a spare stock axle -- left or right side?
#15 |
#16 |
Team VAJJ
You should take pics, We could help you alot more! Regardless, if it's just an axle, that is easy and relatively cheap:)
#17 |
ok i took pictures!
#18 |
If it's any consolation, it looks sweet slammed.
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 10:03 AM |
| Progress Lowering Springs vs Tanabe DF210 lowering springs | jyfro_13 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 03-24-2010 03:38 AM |
| FS: Progress lowering springs | Cvc9216 | Items for Sale by private party | 0 | 10-23-2009 08:41 PM |
| 2006 Toyota Yaris 5dr. LiftBack Lowering Springs | yaya | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 05-14-2009 02:38 AM |
| Lowering Springs - Questions ~ AGAIN ~ | jaspie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 01-16-2007 01:23 AM |
