Old 04-07-2010, 05:44 AM   #1
TDaniel
Drives: Vitz 2003 1.3 CVT
Knocking / Pinging
Hi everyone
I just purchased a new second hand import from Japan Toyota Vitz 2003 facelift model 1.3 with CVT Transmission. It has 60,000ks on it and is in immaculate condition.
When at low revs /under stress when travelling under 70kmh the engine makes a pinging sound. When we put it into sports mode (increases the revs by approx 600) the problem goes away. I have tried a tank of both low and high octane fuel and it has made little difference. Is it a problem with the valves?
Any thoughts much appreciated.
Cheers
TDaniel is offline   Reply With Quote
Old 04-07-2010, 11:19 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Light pinging is normal for the Yaris/Vitz/Belta. The engine's knock sensor will pick it up and let the ECU know to retard the spark a bit before it reaches a harmful level. An engine's most efficient spark timing tends to be right at the onset of detonation under many operating conditions.
Old 04-07-2010, 01:14 PM   #3
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
probably full o carbon. yank the head and clean the combustion chamber of carbon buildup.
127.0.0.1 is offline   Reply With Quote
Old 04-07-2010, 03:19 PM   #4
Yaris Hilton
Smile
No way are those combustion chambers full of carbon at 60,000 kilometers unless that engine's been grossly malfunctioning. Black smoke sort of bad running. A brand new Yaris will ping lightly in normal operation.
Old 04-07-2010, 03:24 PM   #5
127.0.0.1
huh ? mine does not ping whatsoever, and I drive a lotta medium
and stiff grades. knock sensor works. octane is 87
Old 04-08-2010, 05:06 PM   #6
Yaris Hilton
Smile
Your ears likely aren't good enough to hear the light pinging, else you aren't recognizing it. It's there. It's subtle. The knock sensor does work.
Old 04-08-2010, 05:11 PM   #7
127.0.0.1
yaris does sound like a little buggy. perhaps that is where the little buggy sound comes from. it is nothing like 'real pinging' you'd get from a crappy 1981 chevy citation climbing a steep hill
Old 04-07-2010, 08:39 PM   #8
Rick
Drives: '08 Yaris LB 5M
My '08 has a light quiet diesel-like clatter when peaking the instant MPG on the highway. I assume I'm hearing pre-detonation (light pinging) The Chrysler powertrain engineers used to tell me that "pinging is the sound of fuel economy". More recently I was told by a Ford powertrain engineer that "pinging under light loads hurts nothing but pinging under heavy loads will destroy things". I'll let you know if my motor grenades.
Rick is offline   Reply With Quote
Old 04-08-2010, 11:38 AM   #9
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Make sure plugs are tight and correct heatrange. Engine can get carboned up by easy driving - a steam drink of 1/2 L hot water at 3000 RMP >SLOWLY< in through a vacuum hose behind the TB but into the manifold log will decarbon the engine better than any solvent. Just go VERY slow. maybe 5mins to drink the 1/2 litre.
TheSilkySmooth is offline   Reply With Quote
Old 04-08-2010, 06:17 PM   #10
severous01
try running midgrade or premium.
Old 04-08-2010, 06:32 PM   #11
mimelio
Drives: NONE
Try another brand of gasoline just for the heck of it.
mimelio is offline   Reply With Quote
rear suspension making knocking noises jookybanana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-18-2011 02:00 PM
Strange knocking in Engine :( IvanG DIY / Maintenance / Service 10 09-28-2009 09:06 AM
Pinging belt when wet or cold steveh74 Europe (continental) 0 08-22-2009 06:50 AM
Yaris making knocking noise Wass General Yaris / Vitz Discussion 5 12-02-2008 04:37 PM
engine knocking when accelerating hans_fh General Yaris / Vitz Discussion 15 07-04-2007 03:13 AM
