Old 09-15-2013, 08:45 AM   #1
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Subwoofer Help
Hi guys,
My dual 10" ported setup recently gave up on me (pre built) xXX brand (pretty crappy) so I decided to buy two new subs. I didn't appreciate how much space the the dual 10" setup took in my tiny little yaris so I opted for dual 8" kicker subs this time.
My question is, What type of enclosure should I go for?
Subwoofer Features:
8" Single 2 Ohm Competition (Comp) Series Subwoofer
Power Handling:
Peak: 200 watts
RMS: 100 watts
Impedance: Single 2 ohm
Injection molded SoloKon cone
Optimized polyfoam ribbed surround
Extremely rigid cone, along with 360 degree back bracing eliminates distortion
Double stitched surround for enhanced durability
Tinsel leads woven into the spider with Kicker's Spiralead technology
Single high-temperature voice coil
45oz. Magnet structure
Frequency response: 30-500 Hz
Sensitivity: 85.6 dB
Mounting depth: 4-1/16"
http://www.sonicelectronix.com/item_...C82-10C82.html
Recommended Enclosure Specifications
Recommended Enclosure Type Ported / Vented
Sealed
Minimum Sealed Box Volume 0.5 cubic feet
Maximum Sealed Box Volume 1.2 cubic feet
Minimum Ported Box Volume 0.66 cubic feet
Maximum Ported Box Volume 1.2 cubic feet
When I build the enclosure, do I just double the above values since I am using two subs?
Ryze268 is offline   Reply With Quote
Old 09-15-2013, 02:30 PM   #2
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
You could do a single 12 inch. I've got a Morel 10" I run. I made the box, but Morel needs a cubic foot for there 10", so in my hatch back I made the box 12.5x12.5x15.5 The long end is front to back, so I still have lots of room(2/3)in the cargo area.
Anyway, most 12's work well in a 1 cubic foot box. A 12 in a good sealed box can equal 2 10's.
Good luck.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 09-15-2013, 04:47 PM   #3
sqcomp
Roadrunner Jr.
sqcomp's Avatar
One red flag that I see is the same values given for the airspace on the sealed and ported maximum allowable sizes...
You should note that building a sealed enclosure is going to be easier, more controlable and more reliable overall versus an attempt at a poerted/vented enclosure. I'm not saying don't attempt the ported type, just do your research on port size, length vs tuning frequency. You'll be able to save a heck of a lot more room in your Yaris with a sealed enclosure if that's a concern.
What amplifier is going to be driving the speakers?
― Thomas Paine
Old 09-16-2013, 01:00 AM   #4
Ryze268
Ryze268's Avatar
I already bought the Subs from the US & got them delivered so a new sub is out of the question.
I intend to use my old Sony Xploud 2 channel amp (pretty crappy & dated but it works fine).
Its 1000W Max @ 2 Ohms & 500W per channel.
With the efforts of saving space, the sealed enclosure looks like the way to go
Old 09-16-2013, 07:24 AM   #5
Ryze268
Ryze268's Avatar
Well there goes my thread =(
Old 09-16-2013, 04:45 PM   #6
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Them 2 8's will sound ok in either sealed or ported
Old 09-16-2013, 04:48 PM   #7
_S7V7N_
_S7V7N_'s Avatar
Get a box with 1cube per chamber sealed.
Old 09-17-2013, 09:42 PM   #8
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I would build a box with 2 chambers.
D.
CLA 250, 4MATIC
Old 09-18-2013, 08:15 PM   #9
sickpuppy1
Drives: 2010 Yaris Sedan
for a ported box 8" subs are supposed to be in a .3-.6 cubic inch box. I have one in my sedan and every mfg I saw said .3 to .35 cubic inch sealed or .6 if ported I've have several people freak when I open the trunk and they see this little box....sounds good. But with most any 8" of moderate price range, dont be suprised if you miss some of the very low notes. They just roll off pretty hard at about 25-30 hz
Mine is a JBL sub and amp @ 250rms
This is pretty much what I bought
Old 09-18-2013, 08:18 PM   #10
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Just remember that the larger you build the enclosure, the lower the frequency of the sealed enclosure. Be wary though, going below the speaker's Fs through the enclosure chamber size along with overdriving the speaker...that means bad things.
Laymen's translation, don't go too big with the size of the enclosure and don't give it bad (clipped) signal.
Listen to what SP just posted. Don't expect too much from the little woofer. It's not a big speaker. You have to give something to get something...
― Thomas Paine
Old 09-18-2013, 08:29 PM   #11
sickpuppy1
This is pretty much what I have.
http://www.ebay.com/itm/8-SINGLE-POR...642611&vxp=mtr
Old 09-18-2013, 08:32 PM   #12
sickpuppy1
And next time I will go with a single 12, myself. Not for loudness but for hitting the very low without straining. I may try a sealed box to get away from the resonant freg. inherit to a ported box.
Old 09-18-2013, 10:15 PM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
^ hitting the low shouldn't be an issue with the ported box.
Unloading below the res freq is definitely the scary thing. IIRC, the resonant freq of a Yaris sedan is 40-43Hz. If you can design the ported enclosure to couple over or under the vehicle's frequency you'll have an extended "boost" without even touching the crossover section.
― Thomas Paine
Old 11-20-2013, 02:51 PM   #14
UberSilver
UberSilver's Avatar
Did you ever finish your build?
I made a new box for my Morel 10. The yaris now has scary earth shaken bass!
Hi guys,
Subwoofer Features:
Power Handling:
Peak: 200 watts
RMS: 100 watts
Sealed
Old 11-20-2013, 08:55 PM   #15
Ryze268
Ryze268's Avatar
Sorry for the late reply, ended up just winging it and it turned out great.
I went for separate chambers as suggested
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Steps to install a subwoofer in Yaris 2008 HB eepp In Car Entertainment + Electronics (audio / video / alarm) 2 11-20-2013 07:30 PM
Adding Subwoofer and Amp to Integrated Radio bakerman6578 In Car Entertainment + Electronics (audio / video / alarm) 1 01-16-2012 04:34 PM
My new subwoofer setup! Nexus1155 In Car Entertainment + Electronics (audio / video / alarm) 14 12-19-2009 08:11 AM
Yaris Subwoofer shtou In Car Entertainment + Electronics (audio / video / alarm) 2 12-18-2009 12:04 PM
Subwoofer Help - HELP ME PLEASE *MAD DOG* Off-topic / Other Cars / Everything else Discussions 14 10-27-2009 11:25 AM
