Old 04-14-2010, 06:23 PM   #1
swidd
Drives: Yaris HB
What is this rusty looking thing?
Hi,
I just finished taking out and putting back in all my seats, and noticed that on several of the seat bolts that go down into the floor/bottom of the car, the bolts came out with dirty looking rust on them.
Does this indicate that the bottom of the car is rusted? Its only 33 months old..
swidd is offline   Reply With Quote
Old 04-14-2010, 08:55 PM   #2
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Any pics?
Originally Posted by sw07gt
Old 04-14-2010, 10:49 PM   #3
swidd
Drives: Yaris HB
No pictures, I put the bolts back in after spraying with anti rust.
Old 04-15-2010, 05:11 PM   #4
matharris
Drives: 2007 Yaris Sedan (Aero)
It is just surface rust. I work in a car factory and there are certain bolts that the manufacturer want to "rust" and "seize" up so that they don't come loose and fall out. This doesn't mean that the under of the car is rusting, these bolts are designed to do that.
matharris is offline   Reply With Quote
Old 04-15-2010, 06:07 PM   #5
DARK AGE 53
Drives: 2009 Yaris Onyx
Never heard of that, which auto maker do you work for?
DARK AGE 53 is offline   Reply With Quote
Old 04-16-2010, 10:54 AM   #6
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
LOL.
In all my vehicles, the bolts the manufacturer doesn't want to come out
have a threadlocker compound on them, or other retainer.
rust -cannot- be part of the equation because there is a good number of cars driven in dry climates which will never
see surface rust.
so you are going to count on rust ?
fail.
127.0.0.1 is offline   Reply With Quote
Old 04-15-2010, 05:29 PM   #7
127.0.0.1
seats bolts usually stick out the bottom of the car and are exposed to the elements
it is just normal crud. if you are concerned, pop them, lather with grease, replace
Old 04-16-2010, 10:38 AM   #8
+11111111
Old 04-16-2010, 01:43 PM   #9
RedRide
RedRide's Avatar
Bolts that fasten seats to the floor boards are often secured with a threaded, steel insert that does go straight through the floor board.
In other words it's possible that when inserted, the ends of the bolts will indeed be exposd to the elements.
As we all know, it does not take too long for any iron or steel to rust.
This is normally not a problem as seats are one thing that is rarely removed except by some realitively few that install custom seats.
Old 04-16-2010, 04:07 PM   #10
blh4645
Drives: 2008 Yaris Sedan
I work for Toyota in Georgetown KY, building Camry's, Avalon's and Venza's. I can tell you that seat bolts on Toyota's do not go through the floor pan. The bolts that we use are coated with a rust colored substance that works similar to Loc-tight. The bolts are shot with a control tool to a specific torque. They are considered a safety regulated item. I can also tell you that coating these bolts with grease is NOT advisable! Grease on the treads will cause the bolts to stretch and not hold the proper torque.
blh4645 is offline   Reply With Quote
Old 04-16-2010, 04:58 PM   #11
IllusionX
Drives: 07 Yaris Sedan Aero
you have yet to explain the rust on the tip of the bolt though.
last time i pulled the rear seat + the metal frame that bolts to the floor, they were rusted.
Old 04-16-2010, 06:45 PM   #12
swidd
Drives: Yaris HB
Yep, there were only some of the bolts that were rusted. I thought they were only the ones near the wheel wells, didn't quite keep track of it, but indeed, the ones on the bottom rear seat frame had rusted tips.
Old 04-16-2010, 07:16 PM   #13
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
The rear seats bolt into a nut which is welded to the bottom of the body. If you look underneath the car they're clearly visible.
Here's a picture courtesy of owner fmicle.
You can see there's holes at the ends of each nut, so that's why you're seeing rust.
Old 04-22-2010, 12:19 PM   #14
127.0.0.1
he can only speak for what models he builds
not all toyota's are the same
my 4runner seat bolts holes all poke through the bottom, but that
bottom is very high and only rarely do they get wet or crud on them.
after 11 years they have very little rust, but yes they go right through
to open air under the vehicle
Old 04-17-2010, 03:38 AM   #15
shinlee
shinlee's Avatar
Drives: 07 liftback
yeah, I've taken out all my seats in my car, and almost every bolt leaves a nice big hole that I can look at the asphalt through....
they go through the floorboard....
shinlee is offline   Reply With Quote
Weird thing..my left wheel sits in more than the right ezhacker1 Cosmetic Modifications (Exterior/Interior) 33 06-21-2010 03:43 PM
Can someone tell me how to call this thing? window_lee General Yaris / Vitz Discussion 3 10-26-2009 08:21 PM
Which friggin' transmission is in this thing? H3LlIoN Performance Modifications 19 08-20-2009 08:34 AM
Did i do the right thing? strider86x General Yaris / Vitz Discussion 9 10-05-2006 03:52 AM
What is that circle thing? Mad Munchkin Photo-Video-Media Gallery 13 09-26-2006 02:27 PM
