Old 01-22-2010, 03:41 PM   #1
dmfang
Drives: 07 Yaris liftback
K&N Typhoon install
Hi all -
I've got an 07 Yaris liftback that I've done little more than general maintenance to and now I'm looking to amp it up.
I read the reviews on the K&N filters and i'm thinking that might be a good thing to start with. How difficult is the Typhoon to install? Is it something that a mechanical novice like me could even attempt, or should I stick with a basic air filter?
dmfang is offline   Reply With Quote
Old 01-22-2010, 03:56 PM   #2
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
hey buddy
i have the K&N intake on , its great setup , sounds awesome , gives much better throttle response and a few more horses.
its really easy to install , just follow the instructions word for word. one thing i noticed on my car , not sure if its the same for the US cars , but dont disconnect the battery , as it may cause a cell when it starts up and doesnt find OEM flow or wont idle properly and cut out. i had to start the car with the OEM intake on , then after the idling settled i re-installed the K&N without disconnecting the battery and it was 100%.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 01-22-2010, 03:59 PM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
what i actually did on mine is machine out the metal plenum in the intake , its the piece of metal in the intake that give the "typhoon effect" and is suppose to add power , but i found that it actually causes a slight delay in throttle response from the engine , so now mine is like one long ram tube with a filter on the end.
the short ram does suffer a bit from heatsoak under traffic driving on hot warm days , but once you are moving , its 100% again ,im actually trying to figure out a way to get more cold air into the filter. but the short ram i think is perfect , no chance of water in the intake.
JDMtuner
www.jdmtuner.co.za
Old 01-22-2010, 04:06 PM   #4
dmfang
awesome - thanks!
now i think its time to hit the almighty web in search of a good price.
how long did the install take?
Old 01-22-2010, 04:31 PM   #5
The AFE intake is an awesome alternative choice. You'll find many very positive reviews on this forum.
http://shop.microimageonline.com/aFe...L-51-11302.htm
Old 01-23-2010, 08:39 AM   #6
Yarisaur
Drives: 07 Yaris
What would be the best filter to get with the AFE?? they offer two different ones
Yarisaur is offline   Reply With Quote
Old 01-31-2010, 11:14 AM   #7
Yarisaur
Drives: 07 Yaris
Anybody?
Old 02-11-2010, 10:15 PM   #8
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Are you set on a short ram style? You got a lot of heat soak from the engine being that the intake sits in the bay. Cold air versions usually provide more cold air and usally give you more hp gain. not offense but because you sound new to this kind of thing you might want to look around more. California is hot man you might want that slightly cool lower air instead of the burning hot air inside your engine bay lol.
Old 02-11-2010, 10:27 PM   #9
auxmike
auxmike's Avatar
I don't need a CAI.
One day my Scanguage showed 21F for the incoming air! Beat that, K&N.
Save money, go someplace where they have natural cold air....
Winter CAN be good!
Old 02-12-2010, 06:54 PM   #10
1.5
Form>Function
1.5's Avatar
^^ yea i was aiming that towards op who lives in cali.
Old 02-12-2010, 07:34 PM   #11
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
dmfang - if you want true cold air induction, go with a Fujita F5 intake. It is the only intake for the Yaris i know that sits very low (yes, lower than the AEM) hugging the upper top of the foglight cover and side fender wall.
Only problem? Remove during rainy season as it tend to get hit by water more than other intakes available lol...or slip on an Injen Hydrashield cover for the filter...it prevents water being sucked by it, or at least water repellent.
Old 05-04-2010, 08:11 PM   #12
JImbo_2400
Drives: 2D Grey Hatchback
I put the Typhoon on mine and it works great, more HP, sounds better, and the mileage isn't really affected all that much. That being said you do loose a some of the low end power and it does cause an intermittant CEL. I'll try resetting the ECU with the stock intake on then switching over to the K&N with out disconnecting the battery.
JImbo_2400 is offline   Reply With Quote
Old 05-04-2010, 09:31 PM   #13
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
sorry bout the threadjack....but does anybody else have problems with CELs? i thought that was a pretty big problem, with the filter so close to the MAF...i don't like the CAI's, as i would like to try to keep water out as much as i can.. (hurricane season in florida)... but i'm worried about CEL's in SRI's...
goliath1812 is offline   Reply With Quote
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
K&N typhoon maintainaince JapRulezz Performance Modifications 1 12-06-2009 12:41 PM
Toyota Yaris I 1.5 Polished K&N Typhoon FAB Items for Sale by private party 2 10-30-2009 03:57 AM
