Old 03-18-2017, 05:11 PM   #1
David C
Drives: White '07 3dr LB
Oval brake drum ?
Over the winter I've done a few drifting and donut events in the snow for fun and I think that it may have caused my rear drums to get a radial run-out. Do I have to replace the drums or can it be fixed in any way ? I don't mind replacing the drums since they are all rusty on the outside and you can see the ugly trough my mags, but if I do, which brand/series should I choose (is a $30 Raybesto/ACDelco/Centric/Magnelli drum any good ? Toyota OEM seems a lot more expensive) and do I need to do any preparation ? My shoes are still good in thickness when I checked them in fall, but I wouldn't mind changing them too since they aren't expensive either and why not.
Thanks
Envoyé de mon iPhone en utilisant Tapatalk
David C is offline   Reply With Quote
Old 03-18-2017, 07:07 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
just replace drums if all other stuff still good just brake clean it and lube and adjust.
Old 03-18-2017, 09:47 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
It's impossible that you could have caused your drums to come out of round.
What exactly are your brakes doing now?
Sent from my SM-G930W8 using Tapatalk
Old 03-18-2017, 10:33 PM   #4
David C
A slight screech or squeeek and more pronounced pulse at a very specific part of the wheel rotation. Definitively coming from the rear.
Old 03-18-2017, 10:38 PM   #5
tmontague
tmontague's Avatar
Likely have burned pad onto the drum. Like illusion said warping a drum is virtually impossible but a burned pad is slightly more possible. Especially when the shoes lock up the shoes and they're hot that can lead to making hot spot on the drum. ( more common in front rotors after slamming on the brakes on a highwag and then holding the brakes down waiting for traffic to move)
Old 03-18-2017, 11:39 PM   #6
David C
What's the fix for such a thing ? If I need to buy parts, I'd like to know ahead so I can do the swap when I'll change my tires and cleanup the rear brakes in a week or two.
Old 03-18-2017, 11:41 PM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Emery Paper.
Old 03-18-2017, 11:47 PM   #8
David C
On both shoes and drum or just the drum ?
Old 03-19-2017, 07:57 AM   #9
Bluevitz-rs
You can sand everything.
Old 03-19-2017, 08:42 AM   #10
Live with it. It's a minor annoyance not impacting safety. Car is after all 10+ years old.
Old 03-22-2017, 06:55 AM   #11
IllusionX
Best you can do is take drum out to inspect.
Old 03-22-2017, 06:57 AM   #12
David C
Planning to do so when I change back to summer wheels soon.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Drum brake problem. theb DIY / Maintenance / Service 4 04-23-2014 02:04 AM
