Engine's running super smooth now...
The car has run beautifully since I got it but did a bit of a tach dance when idling; going from 600 - 850ish RPM, up and down.
Today I cleaned the MAF sensor (it went from black to shiny), throttle body and pcv valve. The jobs took a total of about 1.5 hours, but this is the first time, so it should go quicker subsequent times. I used electrical cleaner for the MAF sensor and throttle body cleaner for the other two. I thoroughly cleaned the air box. The throttle body had some white corrosion under the hose, so I sanded that all smooth, cleaned up with electrical cleaner, and cleaned the entire hose assembly as well. Naturally, I stuffed a rag into the throttle body opening when sanding so as not to get any debris inside. To get at the inside of the TB, I turned the key on (engine not running) and set the gas pedal down with my son's hockey stick. The TB was fairly clean, the pcv valve cleaned up nicely too. It had a bit of oily carbon on it but nothing caked or gooey. Not sure which of the procedures that I did that smoothed out the idle. In my uneducated opinon, most likely to least likely would be: - MAF sensor - throttle body - pcv valve I also sanded and painted the hose clamps. To celebrate the job, my son and I took a couple of hour drive - lunch in between. What impresses me so much about this little car is its ability to climb long hills without losing speed and barely increasing pressure on the gas. I think I commented on all of this before, but, man, Toyota sure designed this car well! 106 HP, 103 ft/pd torque and sings along effortlessly and handles like nothing else I've owned. I said to my wife, it's like a little thoroughbred... it doesn't like to sit around...it just wants to go! My only fear now is, after reading performance threads, I'm afraid I might get caught up in some more 'expensive' mods. Been reading about the rear away bar.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 10-09-2017 at 03:08 PM. |
Nice!
I love this car as well. My 2007 and now my 2014 have impressed me beyond expectations. The 1.5L motor and 4-speed automatic transmission are brilliant and perform flawlessly. |
#3 | |
Off topic, but do you know of anyone other than CTScott who is selling the cruise control kits? I am dying to get my hands on one. I see the stalks available on eBay and there is a guy that sells the necessary pins/connectors, but I can't find the indicator light module anywhere. I need one of these kits...NOW...haha as I'm still stoked on working on this car. And, I have the install guide. Just hanging on getting the parts.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 10-09-2017 at 04:50 PM. |
Yup, this car still puts a smile on my face every time I drive it!
Sorry, don't know much about C/C. Heard the Rostra Cruise Control Kit 250-1836 is good. Ebay has them for about $165. OBO plus shipping. Not sure if they have the illumination module you're after. http://www.ebay.com/itm/New-Rostra-2...kAAOSwGvhUEwJZ |
#5 | |
Here's a link to the eBay guy: http://www.ebay.com/itm/Repair-termi...ZUE8XL&vxp=mtr
Don't forget to check your intake and cabin air filters.
By intake, do you mean the air filter box? If so, I mentioned that I cleaned that. I actually removed it to do so. If you're talking about cleaning the intake manifold, then I'd have to research how to do that. I'm not a Seafoam kind of guy, so if it involves a spray and a lot of smoke, I'd be too chicken to do that.
![]() Haha, didn't even know my Yaris had a cabin filter. Thanks.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 02-16-2018 at 08:53 PM. |
Cabin filter was seldom installed in the Yaris from new, but it would be a good idea to install a filter, or change it if one was installed.
The cabin filter is located behind the glove box and is easy to access and install in about 2 minutes. I always buy engine and cabin filters on ebay for under $10 for both. |
#9 | |
I'm happy to say that I got in touch with CTScott and I have ordered a cruise control kit. Can't wait!
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
I wish we paid what you yanks pay for fuel. 1.5 would be nice! To have an extra cylinder and .5 litre of displacement. Going up hills in 2nd or 3rd has not been uncommon for me.
![]() That being said I wouldn't swap my car for anything. I've driven a lot of cars for work and while abroad and nothing is as comfortable as my Yaris and certainly not as reliable. When I was in Scandinavia last year there were several days I was driving more than 12 hours and I wasn't even that sore afterwards. Other cars have me feeling sore and fed up after a few.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#11 | |
| NST (NonStopTuning) Pulleys. Info, Specs, User Data... | NonStopTuning | Performance Modifications | 636 | 12-13-2013 09:47 PM |
| Underdrive Pulley | ruimond | Performance Modifications | 17 | 01-12-2009 07:11 PM |
| Fill up with Super before starting your boost project | LtNoogie | Forced Induction Forum | 5 | 12-01-2008 06:41 PM |
| is anyone running this system | angeleyes | Performance Modifications | 2 | 09-09-2007 09:25 PM |
| Anyone Running 15's for Track/AutoX | Vanderkitten | Tracking, Racing, Auto-X Forum | 2 | 06-01-2007 01:12 AM |
