Old 04-28-2010, 10:59 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
C150 Vs C54
I am thinking of replacing my C160 6spd transmission so I am thinking of using my stock gearbox which is a C150 or else the C54.
From research I think that the C150 is owned on yaris models between 2000-2005 while C54 is on 2006-2009 models.
The only drawback is that I will loose the much needed LSD of the C160 so I asked if the C160 LSD can be used on the C150 to "Bluevitz-rs" and he said that the diff do not match the c150 since it is 6bolt instead of 8. Although he said that a C54 diff match the C160.
I am really confused what to decide since the gear ratios of the C150 are better than the C54.
- If I choose to stay C150 I get better gears and I need to buy an LSD (which is expensive) for it
- If I choose to use C54 I get a slight loss of gears ratio but then I can use the C160 LSD
Also I do not know if the C54 and C150 dimensions are the same since I don't want any issues putting it or else not matching drive shafts.
Please help
C150 vs C54 Compared -> http://www.fatboyraceworks.com/gears...raph&Compare=1
Not sure if the C54 final drive is 3.545 please confirm
Old 04-29-2010, 02:53 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
No no, I'm positive the C54 has a 6 bolt diff just like the C150. It was the C56 I was suggesting you use.
Old 05-04-2010, 03:43 AM   #3
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
I'm pulling apart a C56 at home at the moment to see if I can use that gearset and diff in my C150 casings. You just want to go the opposite. Or grab a C52 (3.6 final drive) and see if that will swap in.
rob323 is offline   Reply With Quote
Old 05-04-2010, 10:22 AM   #4
Bluevitz-rs
I don't think you'll have any problems with putting in the C56 gears into the C150 case.
Old 05-04-2010, 05:06 PM   #5
rob323
I'm yet to take some more measurements, but I think the C56 centre casing is longer than the C150. The end casing are completely swappable with the cast end case from the C56 actually being smaller than the pressing steel end case on the C150.
Pulled my lsd apart only to find out that something like a piece of metal has gone through it and put gouges in 2 plates and scored the cross pin . Dunno whether to try and replace them (which probably means buying another bloody lsd) or just polish them up and see how it goes.
Old 05-12-2010, 06:48 PM   #6
rob323
You and your big mouth. You got my hopes up .
C56 gears won't fit in the C150 case.
C150 gear seat on left, C56 gear set on right.
Old 05-13-2010, 04:08 AM   #7
Parmas
Parmas's Avatar
I'm sorry for the this mate but why you wanted the C56 gears?
In my case for drag racing the C150 is better than the C56 because of higher mph across all gears.
Here is a comparism: http://www.fatboyraceworks.com/gears...raph&Compare=1
Left C150 vs Right C56
Old 05-13-2010, 07:19 AM   #8
rob323
I want a closer ratio gear set and shorter final drive because my drag strip can be up to 40 kms long and usually has lots of hills and corners.
Old 05-13-2010, 07:59 AM   #9
kngrsll
Apexing Egg!!
kngrsll's Avatar
LOL
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 05-13-2010, 09:04 AM   #10
Parmas
Parmas's Avatar
As you described we call it hill climb sprint.
Can you tell us why you chose a C56 trans and not a C160 to swap into a C150?
Bluevitz-rs made a good thread that explains it all that it can be done. http://www.yarisworld.com/forums/showthread.php?t=26728
The C160 transmission is a closer ratio than the C56.
The purpose of this thread was in order to know if the C160 LSD fits the C150 that's all
Old 05-13-2010, 05:21 PM   #11
rob323
Hmm, but on dirt. We call it a rally.
Our rules allow us to use what ever gearbox (or combination there of) we like BUT we cannot modify the chassis of the car to accommodate it. The extra length of the C160 therefore makes that swap impossible.
Yep, and a shorter final drive as well and would have been perfect for my needs if it fitted without modification, although I do have concerns that due to where reverse is, that I might accidentally pick reverse instead of first during a down shift into a tight corner, that would be disastrous.
No but yes, the C160 lsd will not slot straight into a C150 diff due to the different number of bolts that hold it to the crown wheel. See pic below. You could however take it to someone and have it redrilled to suit and then it may fit. I'll trial it on the weekend for you just to make sure the heights stay correct.
But after seeing how much smaller the gears and diff are in the C150, I'd be scared at running too much power or abuse through it.
Old 05-14-2010, 04:55 AM   #12
Parmas
Parmas's Avatar
Can you just swap gears from C160 to C150 and keeping the same housing?
The C160 transmission is longer because of the extra 6th gear, well you could use 5 gears instead of 6?
Yea I agree with you. After using the C150 for years, when I switched to the C160 trans I got many times putting 6th instead of reverse but I never hit reverse instead of first. The reverse is far from first and it is not the same horizontal feel shift. Also the 2nd gear is so low that I mainly use it instead of 1st gear when I am in traffic.
The below diff is not of the C160, it is marked C56 or they are the same?
That depends the cost of redrilling! If so it would be more worth buying an upgraded LSD
Old 05-14-2010, 02:05 PM   #13
Parmas
Parmas's Avatar
You got me... transmissions are not my best topic
Old 05-14-2010, 07:14 PM   #14
rob323
An lsd from a C56 will fit a C160 as they are both 8 bolt crown wheels.
C54 MANUAL TRANSAXLE service manual needed ricepower DIY / Maintenance / Service 1 08-29-2007 08:24 AM
