Drives: Yaris 2005 1.3 - P2 facelift Join Date: Nov 2017
Which serpentine belt?
Hi,
My engine has only a single drive (serpentine) belt that needs replacement. It's the 2SZ-FE engine with AC, and currently has a Toyota OEM 6PK1770 belt. However, when I try to locate the correct drive belt on EuroCarParts, I only get two drive belts listed for my engine. 6PK1765, or 6PK1775 - Will that 5mm either way make much of a difference on these engines or should I try to hunt elsewhere for the OEM 1770mm belt? Thanks EDIT: I've found a solution, the Gates 6PK1768 is the non-OEM branded equivalent to Toyota part number 90080-91223 (also manufactured by Gates) - not sure why they felt the need to add 2mm to the print. Last edited by courtartanis; 11-30-2017 at 12:53 PM. Reason: Solution found |
| Tags |
| 2sz-fe, belt, drive, serpentine, squealing |
| Yaris serpentine belt!!! | Ramon1691 | DIY / Maintenance / Service | 9 | 04-11-2016 12:00 PM |
| Squeal from Engine after replacing Water Pump and Serpentine Belt | vidfan | DIY / Maintenance / Service | 7 | 06-24-2014 11:41 AM |
| new serpentine belt | dferguson2 | DIY / Maintenance / Service | 1 | 06-30-2012 09:07 PM |
| Lost Serpentine Belt | NickNickNick | DIY / Maintenance / Service | 33 | 07-31-2011 01:28 PM |
| serpentine belt for 2007 yaris hatchback | nikki9 | DIY / Maintenance / Service | 4 | 04-09-2011 10:22 AM |
