#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
Detailing Methods/Procedures
Due to Wisconsin FINALLY starting to warm up, and also RaptorRacing's recent post, I really want to make my Yaris shine. Thing is, I'm not that experienced at detailing, and I'm looking for some input on the procedure/methods and products used (specific brands not required, but appreciated).
So far, I'm thinking an order something like this: 1.) Rinse/wash 2.) Detergent wash to remove existing wax job 3.) Clay Bar 4.) Polish 5.) Re-Wax Any suggestions?
#1 Lemming
bump
Not required to use a detergent based wash to strip the wax. Cause at the same time it strips nutrients from the paint leaving you with that horribly dull finish. Claybar and polish we will remove old wax and residue from your paint. You will know cause it will have a squeeky clean finish when you are done.
My advise is to first wash then towel dry. Then claybar atleast the roof and hood surfaces. Then use a polish. Then polyermer based wax or sealant. Let it dry for 24 hours and park in a garage if you can to cure and then put on another coat or your favorite carnuba based wax on top for the ultimate shine. |
the trick to using Claybar is to listen to your rubbing motions, dont use too much force, listen and feel for grittiness. go slow and use enough lubricant so it slides easy. ...sounds dirty LOL
but yeah, dont forget to wipe the liquid off, cuz not all of the grit will be in the bar it will be in the liquid. Break off small sections of the bar so in the event you drop it you wont waste an entire bar.
#5 | ||
#1 Lemming
Thanks for the fantastic input!
| DETAILING TIP OF THE WEEK | RevoluScion | Wash, Wax, Detailing, Exterior Repairs | 28 | 06-10-2010 03:02 PM |
| Detailing Tips from AutoGeek | tomato | Wash, Wax, Detailing, Exterior Repairs | 4 | 09-05-2009 02:21 AM |
| detailing shop | seanele | Wash, Wax, Detailing, Exterior Repairs | 0 | 08-24-2007 09:07 PM |
| Turtle Ice detailing spray? | junior | Wash, Wax, Detailing, Exterior Repairs | 13 | 03-16-2007 01:46 PM |
