Old 04-26-2010, 12:41 PM   #1
GrimlockGT
GrimlockGT's Avatar
Drives: 2009 3DR Blizzard Pearl CE
Cold Air Intake - Question
I'm going to add a CAI to my Yaris and was wondering if anyone had any negative experiences after the install. In particular having a Check Engine Light error. CEL's drive me nuts!!
I'm probably going to go with the AFE one.
Thanks
GrimlockGT is offline   Reply With Quote
Old 04-26-2010, 01:37 PM   #2
Going with a known and proven brand you'll have no issues. Just make sure that all clamps are secure and the MAF is properly seated. Most CELs are caused by either incorrect piping size, or air leaks.
(and with this, I have finally hit 1,000 posts.....whew!!!)
Old 04-26-2010, 02:15 PM   #3
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Congrats!
Old 04-26-2010, 07:40 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
+1 on Weeyari , i have an AFE Dry intake , its been on now for 50,000KM
not 1 CEL or any other problems .
Old 04-26-2010, 07:54 PM   #5
Billiam
Drives: '10 White Yaris 4D LB
Just handle the MAF like it's priceless. Don't drop it or bang it around at all. In fact, I recommend that the first thing you do is un-plug it, remove it and set it aside. Then let it be the last thing you re-install and hook up.
Old 04-26-2010, 09:31 PM   #6
GrimlockGT
GrimlockGT's Avatar
Thanks for the input. Good to hear that if installed carefully there won't be any issues.
Old 05-04-2010, 10:24 AM   #7
MUSKOKA800
MUSKOKA800's Avatar
WeeYari,
Didn't Adrian hydroloc / destroy his engine after sucking water in through his CAI?
Or were his extraordinary circumstances we shouldn't be concerned about???
Old 04-27-2010, 11:12 PM   #8
JImbo_2400
Drives: 2D Grey Hatchback
Gotta be careful, I just put a K&N Typhoon Intake on mine and after 250 miles running it with no problems I got a a DTC of P0101 "Mass or Volume Air flow circuit range/performance fault." I cleared it by disconnecting the battery and I'm waiting to see if it comes back. Going to contact K&N to see if they have reports of similar issues with this intake.
JImbo_2400 is offline   Reply With Quote
Old 05-06-2010, 08:42 PM   #9
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
Lightbulb
you might wanna check to see if any oil from the airfilter got onto the MAF sensor it might have triggerred the DTC
OTA'sTOY is offline   Reply With Quote
Old 04-28-2010, 02:10 AM   #10
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
I've got an ebay special INSYS intake, works like a charm for a fraction of the price.
heeroyuy01195 is offline   Reply With Quote
Old 05-04-2010, 10:30 AM   #11
Extraordinary circumstances.
He modified his stock air box. Took the inlet tube which curls up and flipped it so it pointed down and added an extension to it so that the mouth of the inlet tube was way down low. He then encountered massive amounts of standing water driving through one of our biggest rainstorms ever, and vacuumed it up off the road. :(
Old 05-04-2010, 10:35 AM   #12
Personally, I prefer, and am more comfortable with short ram style intakes. Not really keen on those that place the filter in the wheel well. Much easier to address filter maintenance too with short ram.
Old 05-04-2010, 12:12 PM   #13
Note: The OP is getting an AFE, which is more of a short ram style, not a CAI.
It would be practically impossible to get hydrolock with the AFE. The filter is at the top of the engine bay, protected on all sides and sealed against the hood (or nearly so).
Old 05-04-2010, 04:10 PM   #14
^ Yep.
Old 05-04-2010, 04:35 PM   #15
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Looks like you decided on the AFE, but I'll answer your post in saying that I used the TRD (really an AEM) CAI that mounts the filter below the right headlight, then vented my foglight cover to force in cold air, and I had fantastic results. According to my SGII, the intake temps dropped from around 100 F to 1-2 degrees F above ambient air temps.
I commuted in all weather for almost 2 years (Dallas actually has 4 seasons, winter is just short, but spring is really rainy) with no problems, and was very nervous about hydro lock until I checked the filter after driving home in a real gully washer and found it to be fine, with only a little dampness on the bottom side. That included 17 miles of 60mph driving behind other cars on the freeway, rain pouting down in sheets. I never worried again.
Old 05-04-2010, 09:27 PM   #16
suckerface
#1 Lemming
suckerface's Avatar
Wasn't your filter designed to handle wet situations anyways?
Old 05-04-2010, 09:06 PM   #17
06silveryaris
Drives: 2006 yaris
http://www.yarisworld.com/forums/showthread.php?t=27584
Seems like cels happen to most intakes seems like it hit or miss.
06silveryaris is offline   Reply With Quote
Old 05-04-2010, 10:01 PM   #18
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^ I have had three different cold air intakes on my car now since Ive owned it, different brands, filters, everything. I havent had any water issues here in Maine, and usually when it rains here, it RAINS.
I have had the ebay 1st gen AEM knockoff; Bomz cold air, the simota cold air, and now the AFE.
They have been great, never had one CEL
Cold air intake vs air intake Liu997 Performance Modifications 15 11-05-2009 06:32 PM
Have an Cold Air Intake question... TitaniumBarbell Performance Modifications 10 06-02-2009 05:24 PM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
