Old 06-17-2010, 11:03 AM   #1
Ayaz
Drives: 09 4 door sedan
Engine Braking???????
Hi Everyone I have a question. Don't know if thei was covered before, but I'll ask anyways.
There are times when I am driving downhill and my car will, what feels like, down shift. It's a 09 Yaris Sedan. IS this normal? is this what is called Engine braking?
Kinda getting concerned.
Let me know
Ayaz is offline   Reply With Quote
Old 06-17-2010, 11:52 AM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Yep it's normal. When you let completely off the throttle the Yaris enters Deceleration Fuel Cut Off (DFCO) at anything over approx 1100 rpm. No fuel is used during DFCO and you are engine braking. On steep grades the engine may actually downshift to help slow you down, most usually after the brake is applied in my experience. One of my favorite features of this transmission actually.
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 06-17-2010, 11:52 AM   #3
STC
"LibertyRides!"
STC's Avatar
Let me know
Yes! You'll feel like very tiny hesitation... slight jerk and then a smoothing out in the gear you are in. DFCO is working! I drive a manual and it is more apparent in lower gears! The same is with an auto...
Not to worry!
Cheers!
~ Mark ~
Old 06-17-2010, 02:47 PM   #4
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The ECU has "Downhill Logic" built in to sense acceleration with the throttle closed and shift accordingly. If you let it coast from a lower speed and gear, you'll feel it upshift and really take off. Touch the brake and it downshifts to let the engine's drag help slow the car down.
Old 06-19-2010, 12:04 PM   #5
Ayaz
thanks guys, I thought that the down shifting would be a problem, the RPM jumps up so I thought there was a problem...
Old 06-19-2010, 09:48 PM   #6
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
Are you driving in 3 instead of D? It's more noticeable in lower gears.
Yarisduder is offline   Reply With Quote
Old 06-19-2010, 09:59 PM   #7
Ayaz
Nope In D...
Old 06-17-2010, 12:34 PM   #8
Yarisduder
Yarisduder's Avatar
If you're still giving it gas that is not likely to happen, but if you've let off the gas it's normal, and is as you say "engine braking."
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Braking + engine issues EleKid General Yaris / Vitz Discussion 3 04-15-2010 03:35 AM
Gearbox/diff squeak, poor engine braking Kiz DIY / Maintenance / Service 8 08-01-2009 10:35 AM
Engine Braking TRD_dude182 Performance Modifications 11 09-21-2007 10:56 AM
