Old 06-29-2010, 12:03 PM   #1
cdydjded
Drives: Yaris LB Turbo
Just received
Order a week ago from a junk yard in Canada
Old 06-29-2010, 12:29 PM   #2
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Ill take a set of the wheels on the back ground
You know that thing has the actual miles of the original car that it was on and it will not read yours ( miles) unless you take it to a dealer with the right tools. Other then that its awsome having the tac.
Originally Posted by sw07gt
Old 06-29-2010, 07:56 PM   #3
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
What would I need to adjust the mileage? I saw a USDM cluster w/ tach on ebay awhile back for $50 and I would have gotten it, but the mileage was off and I was told by a Toyota mechanic that it wasn't going to be as easy as it sounds...
Old 06-29-2010, 09:02 PM   #4
Changing the mileage requires reprogramming a EEPROM IC on the cluster. It can't be done using the Toyota Techstream service tool, so most dealerships order replacement tachs with the mileage pre-programmed for the car that it is going into. There are speedometer repair shops that have the necessary equipment to do the programming.
Old 06-29-2010, 09:34 PM   #5
cdydjded
It has to be from a Hatchback, if not it will not work. Toyota mechanics as smart & well trained as they are will always say it work work until they try it.
Old 06-29-2010, 12:32 PM   #6
cdydjded
If you like wheels check out my company www.traklitewheels.com. As for the miles it not a big deal to me, we dont have inspection here......
Old 06-29-2010, 12:46 PM   #7
JumpmanYaris
USAF_SrA_E-4
pmd
Old 06-29-2010, 12:56 PM   #8
SAV912
Pirate Yaaaaris
SAV912's Avatar
o_O
With how many thousands of Yarii that have been sold in the USA, why do people insist on getting Canadian ones with KMH? Baffles me.
Another guy did this recently out in Arizona and for the life of me, I couldn't understand why. A tach is not necessary for these cars, but if you want it and tanking the resale value on your car is worth it, more power to ya.
-SAV
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 06-29-2010, 01:03 PM   #9
JumpmanYaris
USAF_SrA_E-4
Originally Posted by SAV912 View Post
o_O
-SAV
Old 06-29-2010, 01:24 PM   #10
cdydjded
o_O
-SAV
The reason I want a tach is because I run 1/4 at least once a month. My car is turbo if you did not notice. Im tired of hitting the rev limiter every time I shift. Also the reason for getting a Canadian cluster is because they had tach's in the HB since 2006 & the US models with tach's were from 2008+ S models which are very rare. As for the resale value, if and when I decide to sell I can always reinstall the original cluster.
Old 06-29-2010, 07:50 PM   #11
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
awesome! Can you please tell me what junkyard you ordered it from? I have been looking all over for the hb 5 speed manual cluser with tach and cant find..was it just plug and play?
DeathBeard is offline   Reply With Quote
Old 06-29-2010, 09:35 PM   #12
cdydjded
Yes plug & play. Im going to get in contact with the place I bought it from to see if they have anymore. Maybe we could get some group buy goin, who's interested?
Old 07-02-2010, 04:57 AM   #13
SAV912
Pirate Yaaaaris
SAV912's Avatar
All valid points. I noticed your car was turbo, it's definitely a hot ride. I wasn't trying to be a total doucheface about it, I was legitimately asking, and thank you for actually responding instead of just like the other meathead.
I don't like how they light up amber either. I have an '09+ and the lady has an '08. I like her cluster better, but at least my amber matches my radio and air con. Hers is white/green. Odd. Keep the resale value thing in mind though, because you can't just swap back to the old cluster and then sell the car. The old cluster won't be accumulating miles on it while sitting on the shelf in the garage. I see this answer a lot when cluster swapping comes around and I wonder if people actually think of this.
Then again, I guess if you're turbo'd and all that warranty-voiding jazz, then incorrect mileage isn't really going to deter you. Again, nice ride.
-SAV
Georgia Bulldogs!
Old 06-29-2010, 09:32 PM   #14
cdydjded
Installed and working. Only issues:
1 The color it lights up in, amber, didnt think about that, oh well no big deal, Ill change the rest of the car to amber
2 Airbag(right side top), ABS (right side bottom) & a mystery indicator (bottom) is on, solved it by taking the cluster apart & covering the indicator with a permanent marker. Check engine is on cause I do not have a catalytic converter.
Old 07-03-2010, 02:41 PM   #15
Meteorite_Marty
Attachment 34787
You have AMBER because this was pulled from a Canadian RS model. The non-RS models are exactly the same display, except they are a WHITE LED instead for the back lighting.
Old 06-29-2010, 09:57 PM   #16
cdydjded
Here is a short video, more to come soon:
http://www.youtube.com/watch?v=RA_RsJ7avr4
Old 06-30-2010, 12:41 AM   #17
custom Lftback
custom Lftback's Avatar
instead of changing all your lights to amber why not just change the gauge color?
C-Lift
Old 06-30-2010, 10:57 AM   #18
cdydjded
Its easier to change the color of the A/C controls than the cluster.
Mind Blowing Email I received *MAD DOG* Off-topic / Other Cars / Everything else Discussions 19 06-14-2010 11:26 PM
Received Header & Exhaust..Install Soon AlainMikli Performance Modifications 16 04-26-2009 12:42 AM
Anyone received a call for a survey? YarisFan007 California 1 02-15-2009 01:40 PM
I received my new rims today, now... REM Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 02-13-2009 11:57 PM
Package received from Taiwan! GabL Cosmetic Modifications (Exterior/Interior) 74 09-25-2007 10:37 AM
