Old 05-27-2010, 04:15 AM   #1
dante2086
Drives: Toyota Yaris 07
Missing Dimmer Switch
Hey guys what's up. I have a real problem, my dimmer switch is missing from my 07 Toyota Yaris, cuz of this, my dashlights and radio lights don't come on at night, or when I switch on the headlamps.
I can't find the part in my location for the love of me. Please could I get help on how to rewire it to work without the dimmer, even if it means constant full brightness.
THANKS.
dante2086 is offline   Reply With Quote
Old 05-27-2010, 09:17 AM   #2
If the wiring for your Yaris is the same as ours here in the US, then to bypass the dimmer rheostat on the connector for it, you just need to connect the white wire with a black stripe (ground) to the light green wire and the orange wire.
Old 05-28-2010, 03:04 AM   #3
dante2086
Yes, it's actually the US model I own, with the 1.5 litre engine.
Thankz I'll try it.
Old 05-28-2010, 05:44 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
I have 1 you are welcome $15.00US Shipped
Old 05-28-2010, 11:08 AM   #5
dante2086
Cool, how can I get the money across and how're you going ship it. Cuz I'm interested.
Old 05-28-2010, 11:16 AM   #6
dante2086
And i wonder if anyone knows the function of each wire in the assembly, so I can get a better understanding. And what do i do if the white connector is missing, it's just a jumble of wires. And by the way, mine's a sedan. Thankz
Old 05-28-2010, 01:59 PM   #7
10 Pin connector D29
Pin 1 - N/C
Pin 2 - Light Green: Output to radio, AC lights, etc
Pin 3 - White/Black: Ground
Pin 4 - N/C
Pin 5 - Brown: Power in from PANEL1 fuse
Pin 6 - N/C
Pin 7 - N/C
Pin 8 - Yellow: Output to Cluster
Pin 9 - Orange: Output to Hazard warning signal switch and Door lock switch
Pin 10 - Sky Blue: Power in from GAUGE Fuse (Ignition switched)
Old 05-28-2010, 02:23 PM   #8
dante2086
I tried to rewire the dimmer assembly as the switch is missing and I couldn't find it to purchase.
I made the mistake of cutting off the 10 pin connector to do this, and now it's like the car has gone beserk.
The battery isn't charging, the airbag isn't working, the ABS isn't working, the power steering isn't working, the gear isn't shifting. It's like the car is dying, Help please.
Old 05-28-2010, 07:52 PM   #9
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
sent you a PM
Old 07-15-2010, 07:49 AM   #10
dante2086
So i did as u said and all the lights except the speedometer cluster are on now, the radio, the AC lights, the gear box lights too.
What do I do, and what fuse controls those lights, in case the fuse is blown.
Old 07-15-2010, 09:00 AM   #11
Check the MET, PANEL1 and GAUGE fuses.
Old 07-15-2010, 12:53 PM   #12
dante2086
SORRY, didn't write that last post properly.
The AC, gear box, and other lights are working.
Only the speedometer cluster is still not on.
And u told me not to connect it's yellow wire.
My gauge switched is fine.
But which fuse controls the cluster, and if the fuse isn't blown, what should I do.
THANKS
Tags
dash, lights, rheostat
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 09:42 PM
F/S Dash Light Dimmer Switch 1NZYaris1 Items for Sale by private party 4 09-26-2012 04:55 AM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 12:12 PM
Dimmer Switch Question sroberts General Yaris / Vitz Discussion 3 10-16-2006 11:51 AM
