Old 10-06-2009, 01:00 PM   #1
Split
Drives: 2008 Yaris Sedan
HID Kit High-Beam Cluster Indicator Problem
I have done extensive searching and cannot find anyone with the same problem. I bought this kit:
http://www.retrosolutionsllc.com/ser...VERSION/Detail
Its a moving type dual bi-xenon H4 kit. It operates perfectly. I has a shield which reduces glare, and when you switch to high beams, something in the bulb moves and it shifts the light upwards.
The only problem is, the high-beam indicator light does not appear on the gauge cluster, which sometimes leads to forgetting that the highbeams are on, or turning them on by mistake and not realizing. Does anyone have any suggestions regarding this or have had a similar problem? I'm not sure how it works, but I have a feeling the highbeam wire actually powers a magnet that shifts the bulb, but i'm not certain, just speculating.
Split is offline   Reply With Quote
Old 10-06-2009, 01:09 PM   #2
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
Something is not wired in correctly. If you are moving your High-beam control into
the High-beam position, the dash light should come on.
Judging from your location I'd guess that it has something to do with you DRLs?
How did you connect those, or did you fun a bypass to shut them off?
kargoboy is offline   Reply With Quote
Old 10-06-2009, 01:12 PM   #3
Split
i just disconnected the whole DRL module underneath the dash. Does that somehow disable that light?
Old 10-06-2009, 01:36 PM   #4
The DRL module isn't really involved in the beam indicator. The beam indicator always has 12 V going to it and then the ground leg gets switched by the headlight switch. If you check the two pins involved on your sedan's cluster I have a feeling that you are lacking the +12, not the ground when high beams are on.
Pin 14 (gray wire) on Connector D76 (for the Sedan) should be hot with +12V at all times.
Pin 11 (pink wire) goes to ground when the headlight switch is in the high beam mode. If you measure voltage on it, it should read about 1V less than pin 14 (provided that pin 14 is hot) when the high beams are off and 0V when the high beams are on.
If Pin 14 is not hot, and Pin 11 measures 0V with the high beams off, you can measure resistance (Ohms) between pin 11 and ground. it should be open (OL or high value) with the high beams off and 0 Ohms with the high beams on.
If Pin 14 is not hot and Pin 11 functions correctly, then the problem has to do with how the HIDs are cut in to the existing wiring. If that is the case and you can post the wiring instructions I can help further...
Old 10-06-2009, 02:14 PM   #5
I know about this problem. There should be a leftover harness with the installation of that kit, the harness needs a resistor, then your high beam indicator will work.
PM "miniTRD", he knows the fix.
Old 10-07-2009, 06:57 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
That's weird.. why does this happen to you guys?
Mine's working perfectly..
THOUGHT... my setup have one thing different that you guys... (before i did the DRL mod) my high beam indicator always worked. So.. what is different in my setup is the relay i have. My HID are directly connected to the battery with a relay.. where the oem harness switches that relay...
Old 12-31-2009, 06:18 PM   #7
upgradedyaris
Drives: Yaris & Supra
Did this Scott and thanks! Mine works again with the HID's. :)
Now need to know what they do since my Supra has the same problem.
Duane
upgradedyaris is offline   Reply With Quote
Old 02-07-2010, 08:43 PM   #8
shastatodd
Drives: 2009 RED Yaris
Thank you Scott & Mike!
shastatodd is offline   Reply With Quote
Old 02-08-2010, 06:45 AM   #9
yaris2010RS
yaris2010RS's Avatar
i had the same problem when trying to disable drl's. i took out the module and was very happy for about a min.... with the module removed the DRL's, fogs and highbeams no longer worked...... u need to put that module back in but to disable the DRLs u need to cut the big blue wire (i opened up the module and cut the connectors right off the chip ) and everything works perfectly...... except the DRL's. if u are completly lost i'll try to get picks up by week end.
jsut a side note.... when i had the problem i didn't have any HID's installed so if the problem is dirrectly related to them then i dont think the module will be too much help..... give it a shot if u like
Old 02-09-2010, 01:15 PM   #10
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
this is the simplest fix.
I used the right side (unused) Original Headlight socket to make these connections.
50 cents and done in a jiffy. If you want to make it "professional" looking. buy a connector from Radio Shack and fabricate the wiring on that, and plug it into the old harness.
bobolinko is offline   Reply With Quote
Old 02-19-2010, 03:21 PM   #11
shastatodd
The previous (cluster) "fix" did not work, but this one (the under hood fix) did resolve the issue. I DID use the 10K ohm resister in series with the gray instrument cluster wire to dim the overly bright blue high beam indicator... so this is a bit of a hybrid method taking the best of the two fixes for the non-functional high beam indicator problem after the HID conversion.
Todd
Old 02-19-2010, 03:51 PM   #12
Todd
If you are under the hood, installing the HID kit, then this method is definitely easier. When you say that the first didn't work for you, did you actually snip the gray wire and leave the harness side disconnected (as opposed to tapping to the still connected gray wire)?
Old 02-20-2010, 01:00 PM   #13
bobolinko
Bob
bobolinko's Avatar
No, didn't have to snip the wire since the original R/H socket is not used with my HID kit. The kit has a complete harness with 2 bulb sockets. The kit plugs into the L/H bulb socket on the stock harness and feeds both left and right HID's
The stock harness still has related connections since nothing was ever "cut" to install the kit. Analyzing the circuit, the new low beams had no trickle circuit to the inst. cluster since it was isolated with the use of a new harness that only had connections from the ballast for power to fire the HID's
the Halogen bulb actually feds the indicator circuit so without the bulbs, no indicator illumination. Also remember the ind ckt is not High beams on, but more like low beams off.
Old 02-22-2010, 02:04 AM   #14
shastatodd
Yep I did clip the gray wire and connected the cluster side to the black wire on the right side connector. No joy, but the under the hood fix worked great, and since I clipped the gray wire I soldered it back together with a 10K resister in series to dim the obnoxiously bright blue high beam indicator.
Todd
Old 03-02-2010, 05:44 PM   #15
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
can somebody post a picture for this fix! I'm not really into electronics and would like to figure out how it's done. Thanks
CLA 250, 4MATIC
Old 05-14-2010, 04:01 PM   #16
joeljcruz86
Little Eggy
joeljcruz86's Avatar
Drives: Toyota Yaris Liftback 3DR 2009
Send a message via AIM to joeljcruz86
-I have the same problem but I don't understand what I am suppose to do with my leftover stock harness with this diagram.
joeljcruz86 is offline   Reply With Quote
Old 02-21-2010, 08:30 AM   #17
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I used CTScott's method listed above and it worked perfectly for me.
DerFlosser is offline   Reply With Quote
Old 04-10-2010, 11:36 AM   #18
nick.dollimount
Yaris = <3
nick.dollimount's Avatar
Drives: '08 Sedan - Flint Mica
Hey guys,
With the help of Bobolinko, I think I've come up with the easiest method and least invasive. Please see the attached pictures.
The resistor used is a 10Kohms resistor (Brown - Black - Orange - Gold/Silver). It took only 5 minutes to put together (10 if you count the time sifting through a bag of resistors to find the right one ).
With the right hand side unused headlight plug facing you, insert one spade connector into the right side of the plug and the other spade connector in the top-middle of the plug.
Thanks Bobolinko for all your help and speedy responses! Greatly appreciated! I'm sure I'm not the only one who will be greatful either. Goodluck everyone and enjoy your high beam indicator!
..:'; Nick ;':..
2008 Yaris Sedan - Flint Mica
Debadged Rear; Blue Interior Styling; Toyota Sports Pedals; AM Exhaust Tip; OEM Spoiler; Upgraded Speakers; Sony Xplod BT 2600 Deck; Infinity Basslink SUB/AMP in Trunk; 16" Konig Rims; 6000k HID Bi-Xenons; 6000k HID Fogs; NST Short Shifter
nick.dollimount is offline   Reply With Quote
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
Hi & Lo Beam HID Conversion Kit OgDogg Items for Sale by private party 0 11-11-2008 04:55 PM
