Who said Yaris was slow?
Yaris Curb Weight, difference LB vs Sedan
Hey any body have the Curb Weight data for the LB and the Sedan???
I was looking for that information on the internet and I found that the LB is actually a few pounds heavier than the sedan. That just doesn't make sence to me. This is what I found: LB / MT 2290 lbs LB / AT 2335 lbs Sedan / MT 2288 lbs Sedan / AT 2321 lbs Something else that doesn't make sence. If you calculate the extra Weight added by the AT, it adds 33 lbs to the sedan and 45 lbs to the LB.Any comments? |
![]() ![]() ![]() ![]() Drives: 2007 Black Yaris sedan Join Date: Sep 2006
Wow,I got the lighter car,ROTFLMAO.If thats true,thats really weird.
![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
The curb weights (US versions) are shown in this thread:
http://www.yarisworld.com/forums/showthread.php?t=16 Go to the last page of the Technical Specifications List in Post No. 2 there and you will find that the curb weights of the sedan and the LB are the same. That applies to both the manual and automatic models. The specifications there are said to be preliminary though (see the upper right corner of the said page). |
You are welcome! Now I have these links to the specifications of the Canadian versions:
http://www.toyota.ca/cgi-bin/WebObje...40e%2ehtml http://www.toyota.ca/cgi-bin/WebObje...126040e%2ehtml These pages are from Toyota's Canadian website. The weights are there, and I believe that they are not preliminary. The figures do show that the sedan and the HB have different curb weights. If one happens to have a hatchback, it would appear that whether one's car is heavier than a sedan depends on what trim one has. The lightest HB has a curb weight of only 2,300 lb and the heaviest, 2,385 lb. The lightest sedan's curb weight is 2,315 lb and the heaviest, 2,348 lb. I am not sure but I guess you may be able to find similar information on Toyota's websites for other countries. |
![]() ![]() ![]() Drives: Yaris 3dr Hatchback Join Date: Oct 2006
so bassically, they are the same, when you consider the varying weights of all the people driving. but whre is that weight at respectively? does the hatchback have more weight in the rear compared to the sedan? or more in the front?
#6 | |
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
The Sedan's roof is lower (the distance between roof and floor) than the HB's. So there's a weight difference. Otherwise, the Sedan has more weight in the rear because of the trunk. On the lowering springs specs the Sedan lowers 0.1" FR./ 0.3" RR. more than the HB - for the same spring. |
so that means that the hb would have better grip or something? and handle better going up steep hills and terrain? because the FWD combined with additional weight up front? but it would also be easier to EDIT: SPIN OUT:)? BUT most importantly, i have worried about moving up mountains and stuff? anybody know if there is an incline at which we would not have traction due to lack of front weight? or at which the HB woudl be better than a sedan traveling uphill?
Small Car Lover
Its pretty rare and hard for a FWD car to fishtail, that's mostly associated with RWD. I guess if you go around a corner really fast you can bring up the rear and that will spin you out or you will lose control.
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. |
Despite the the fact that the HB is lighter, there should be no difference going uphill. However, the sedan might be more stable and more comfortable on highway because of the extended wheelbase. It also has more roll than the HB. Go Sedan for lots of highway, and HB for city driving. Careful with Sedan if you are a tall person - the roof is lower.
That Anime Guy
If I tackle a corner too hard, my liftback will kick the rear end out in a heartbeat. There's no weight in the back and it still has stock struts so yeah...not good on a top-heavy car.
WELL i was kind of saying that when you have something that weighs 2,300 pounds 50 pounds isnt really going to have any affect for regular driving...i mean if you are at the track and every .01 seconds count, sure it matters...but not much for me. I was wondering though, if the hatch back had a significatly greater weight in the front, or if the difference in front to rear weight ratios were small enough to be negligable(sp?) between the two models. I did not understand the spring things mentioned above, if somone wanted to explain how that reflects on the percentage weight in front and rear and the difference between the two that woudl be awesome.
#12 | |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
We just need to fond the weigh distribution probably it would go something like 60/40
I Drive a 129whp Yaris ;) |
4m a 92 teg 2 a 07 yaris
Drives: 92 acura integra ls, 07 yaris Join Date: Mar 2006
thats the first thing i looked into before i bought the car, i bought the sedan because it was lighter.
Thanks for the info... But any way, It doesn't seem like both version would weight the same. That's odd.
It's too bad that Toyota releases such thing as a preliminary spec. I mean, how hard is for them to just weight the cars??? |
| Yaris Sedan Vs. Yaris 4dr. hatch | Meow | General Yaris / Vitz Discussion | 11 | 10-29-2006 03:11 PM |
| Yaris or Yaris S sedan? | glockprime | New YARIS Purchase Forum | 2 | 09-12-2006 10:32 AM |
