![]() Drives: yaris yr Join Date: Jul 2010
HID help pleeeeeeeees
hi all , just i fit my hid kit today and when i start the light it's work fin and switch it off and when i start the engine and switch the light on the light stop working and when i try agine one light work and the other one no and the one it's not working just flash in the strater and some time work but must of time it's off , pls help me what i have to do please ??????
Are you installing High/Low HID?
toyota
check crossed wires... and DRL
toyota
im assuming it works when the car is off..and not if its on..dont know if you guys have drl in australia..but your ballast might not turn the hid on if you have drl.due to flicker..but i could be wrong..
Did you have a direct (+) to the battery and a separate (-) to the chassis?
HID won't work when Day time Running Lights (DRL) Yes check the fuses for now. |
#8 | |
When you drive during the day does your lights turn on by it self?
DRL turn your lights on automatically during day light at about 50% in my case I don't have DRL and so forth to turn the lights on during the day I have to turn the switch for lights. does it helps? D. |
thanks that's really help , and i don't have this system in my car , till now i search for the soulation but i don't get any think !!!
![]() Drives: 07 yaris sedan Join Date: Apr 2007
![]() thats the only pic i have right now to show you a little about conecctions, its pretty simple as you can see hahaah, you have a positive wire to the battery hopefully with a 30 amp fuse, a negative to the battery, and the H4 conector, the relay gives signal to the right side so you dont need to plug anything on the right side only the wires from the relay, also on the right side u have a negative (ground), thats pretty much all. |
toyota
try switching wires..due to reverse grounding system..red to black. black to red
thanks guys for all this helpfull replys finlly i find the problem it's from the blasst cos when i switch the light on just onley one blasst work and make noise but the othe one some time work and some time not , so dos any buddy have ant seggest to solve this !!!
#14 |
![]() Drives: yaris sedan 2009 Join Date: Jun 2010
do you need a ground on the right relay? you can try to direct your ground from the right side to the + side of the battery, but im sure you will still have the flicker problem so get a grounding kit that has a circuit box if you're catching what i mean :D
| FEELER: Possible New HID Vendor | hydrohopper | Cosmetic Modifications (Exterior/Interior) | 17 | 06-11-2010 02:05 AM |
| XenithXenon HID Conversion Kit | CorSport | CorSport | 0 | 09-03-2009 06:11 PM |
| KLight HID Conversion Group Buy!! $165.00 shipped!! | JRT lighting | Sponsors Classifieds Area | 4 | 11-20-2006 11:47 PM |
