Old 07-30-2009, 04:10 PM   #1
nickstamat
Yaris Lunatic!
Drives: Yaris 1.33L (1NR-FE) 3dr 6MT
1NR-FE Performance & Tuning
Well, this is my first post here, so hello everyone!
I own a Yaris with the new 1NR-FE engine. I would like to find out what are the tuning options that we, owners of a 1NR-FE engine, have.
It seems to me that not even an air intake has been made for this engine yet, so I'm posting here in case some of you have got some lucky find.
I'm pretty sure I am not the only one having this engine here and interested in tuning options, so let's post here everything we've got.
nickstamat is offline   Reply With Quote
Old 07-30-2009, 05:24 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
NEW ENGINE means NO parts yet......
Old 07-30-2009, 06:39 PM   #3
what is the displacement?
Old 07-30-2009, 06:44 PM   #4
ROCKLAND TOYOTA
TRIM HUNTER
1.3 1NRFE
Old 07-30-2009, 08:37 PM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Unless this new engine gets to the US in any other Toyota, then probably will never have any aftermarket support...
I'm lucky that the yaris TS shares the engine with the US scion xD and Corolla
Old 07-31-2009, 02:06 AM   #6
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Welcome bro !! post a pic of what the engine bay looks like, maybe there are similarities. We have got those engines in our new corolla's its a 73kw 1300cc if i remember correctly , a dual VVT 1300.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 07-31-2009, 05:20 AM   #7
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
you might find , things like the motor pullies are the same , but that would be about it for the engine , as it is orientated 180degrees too the 1NZ-FE and the 2NZ-FE.but all the suspension compenents will be the same .
Old 07-31-2009, 09:13 AM   #8
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
if this is the case then going turbo will be a LOT easier for you
Originally Posted by xnamerxx
you nailed it sir.
Old 07-31-2009, 02:31 PM   #9
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
βρε συ... αυτό το μοτέρ δεν το έχουν στην αμερική.
ούτε η blitz δεν το ξέρει. στο λέω γιατί ρώτησα για κάτι.
yaris 2sz is offline   Reply With Quote
Old 08-02-2009, 04:00 PM   #10
nickstamat
Yaris Lunatic!
Guys, I know it is a new engine and this means there are no parts yet.
However, I started this thread because I am pretty sure that there might be similarities with older engines in some parts.
The member Kongo-Otto has posted some engine bay pics here: http://www.yarisworld.com/forums/sho...3&postcount=64
Thanks
@ yaris_2sz: Γεια σου φίλε μου! Το γνωρίζω ρε συ ότι δεν κυκλοφορεί εκεί, αλλά ψάχνω από δω κι από κει για να βρω πράγματα. Δεν είναι ότι καίγομαι αυτή τη στιγμή να το βελτιώσω, απλώς μου αρέσει να ασχολούμαι και δεν βρίσκω τίποτα. Anyway, τα λέμε στο ελληνικό φόρουμ ;)
Old 08-04-2009, 07:54 AM   #11
suiller
Drives: Yaris Sol 1.3 dual VVTi 101hp
I've the same engine (from Piedmont - italy)
it works very well & push enough, even if I miss a lot the "kick in the ass" typical of turbo charged engines
anyway the car runs really smooth & comfortable to drive even if it has a sort of nightmare clutch/gear combination (6 speed)... expecially when cold from 1st to 2nd gear is a disaster, you can't shift at too high ranges (already changed with Redline MT-90)
if you need some specific info feel free to ask
my actual mods are:
1. ZX1 anti-attrite (everywhere)
2. Redline MT-90 gear oil (a bit better)
3. UltraRacing 19mm rear sway bar... thx Garm
4. K&N Air panel (no. 33-2211)
planning mods:
1. new & lighter rims
2. new rotors/pads set
3. I'd like to try crank pulley but I'm not sure it will fit...
bye,
davide
Yaris Sol 1.33 dual VVTi model 09 - 5dr
1. full ZX1 additive treatment: oil + cooler + fuel
2. NB treatment: motor oil
3. K&N panel air filter (part num. 33-2211)
4. Fuchs Silkolene Pro SRG 75 gear oil (the best!)
5. UltraRacing 19mm rear sway bar
suiller is offline   Reply With Quote
Old 08-16-2009, 02:53 PM   #12
nickstamat
Yaris Lunatic!
Thanks for helping and posting your mods, suiller.
Old 03-05-2010, 04:11 PM   #13
ckiriako
Drives: 09' yaris 1.33
Any news and mods for that engine?
ckiriako is offline   Reply With Quote
Old 05-06-2010, 12:35 PM   #14
suiller
I'm looking for a "serious" intake... something like Fujita
this should fit
Old 05-06-2010, 12:51 PM   #15
Kongo-Otto
Drives: '09 Yaris & '10 Auris
This cant fit because the 1NR-FE has the exhaust header at the front and the intake manifold in the back. Something new has to be developed for this engine.
Old 05-07-2010, 05:19 AM   #16
suiller
yep, you're right but it was just an example... I was thinking that was possible to adapt some other "simple" intake, but perhaps it's too complex
anyway I studied the situation again and I was thinking also to leave untouched the original airbox, just (as I did) replace the OEM filter with the K&N (33-2211 model) and removing the original arm...
as you know the original arm seems too thin & above all it doesn't turn close to the floor, so it sucks (almost) warm air
the idea was to remove the OEM arm & installing something like RamII (80mm section) downturing it close to the floor near the right fog lamp
do you have some other ideas??
Old 05-07-2010, 06:01 AM   #17
Kongo-Otto
Its thin and surprisingly short but you dont have to remove it for intake air temperature issues because there are none. I measured the intake temperature with a Scangauge II. Its warm while you are not driving but as soon as you are moving it sucks cold air.
Old 05-07-2010, 06:11 AM   #18
suiller
so you think is useless to enlarge arm section?
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 10:08 AM
New shift knobs available from TWM Performance! TWM Performance TWM Performance 3 06-25-2009 05:24 PM
Anyone need ECU tuning done on American Vehicles? Nexus1155 New England 5 06-10-2009 08:15 PM
Save $20 on every TWM Performance short shifter/shift knob combo! TWM Performance TWM Performance 4 05-29-2009 05:36 PM
Yaris Performance Specs neohalo Performance Modifications 22 06-24-2007 09:46 PM
