Rollerskate
turbo feed lines
where is the best place to tap a oil feed line on a 09 yaris
one good place is where the pressure sensor is.
http://www.glowshiftdirect.com/oilfi...-34unf-16.aspx
Should be more than it's worth. HIGHLY recommended. |
Rollerskate
thanks for the help
#5 | |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I tapped at the pressure sensor. My oil feed line came with a T-fitting to mount the sensor and line.
Rollerskate
i know this is a dumb ? but where can i find the oil sensor Ive looked all over the engine bay and didn't come across it
Haha, I asked the same thing originally. No, it can't be because the oil filter is pressurized. It can only be used as a feed (that means it can be used for oil pressure readings as well).
Yeah, it's stupidly difficult to get at. It's right by the starter, and directly under the intake manifold. I'm pretty sure you'd have to take the manifold off, because I couldn't even get at it from the bottom. |
It's so easy to get at from the bottom. Just take the starter off. It's two 14mm bolts.
C'est la vie
If U removed the front bumper cover witch is pretty easy and then U removed the plastic shroud that is to the left of the radiator [two plastic clips hold it in]. You will be able to get it from the front very easily. Wide open working conditions. If your installing a intercooler U will need to remove the bumper cover anyway. You will need a 24mm deep well socket to remove the sensor.
Rollerskate
thanks again guy right now i have a turbo kit on the was ill let yall know how its going
| FS: 2005 Scion xA RS2.0 Turbo | uberegg | Cars for Sale by private party | 40 | 04-03-2010 12:45 PM |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 11:24 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 12:59 PM |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 01:30 PM |
| delayed turbo project... | joey1320 | Forced Induction Forum | 8 | 09-27-2007 12:18 AM |
