![]() ![]() Drives: 2009 Yaris LE 5 dr Join Date: Feb 2009
Wind whistle from front windsheild
![]() I was cruising around the perimeter highway last night at about 90 kph (55 mph) and noticed a steady whistle coming from the front window. There was a small headwind so my "airspeed" would be closer to 100 kph (60 mph). ![]() I have only had the 5 door for a month or so and don't do a lot of highway driving but WTF, it was loud and annoying enough to make me very unhappy and surely the speed I was going can't be enough to cause some weird whistle can it? I searched before I posted and couldn't find any answers so I was wondering if this is a common issue or unique to my little white hamster. ![]() btw the noise goes away at about 80 kph and my factory stereo needs to be at 40 or higher to drown out the whistle. Last edited by kenora; 04-09-2009 at 09:31 AM. Reason: shi..y speeeling |
#2 | |
![]() ![]() Drives: 2007 toyota yaris Join Date: Mar 2009
toyota
windshield leak check for the rubber seals around it.
Learn to Relax
Make sure window is closed completely and nothing is jammed.
Darrin
Was there a cross wind coming across your car?Sometimes that could make the noise.
All the windows were closed (I checked), I switched from heat to vent to windshield heat to recirculate etc etc and no changes, possibly a bit of a crosswind but the route I took involved going south then west then north so it should have canceled out somewhere in there and no change to the damn whistle. I called the dealer and they said they would have a look when I brought it in for an oil change in a couple of weeks. I'll report back with the results.
Darrin
Oh well, it was a thought.
BTW, which dealer?
![]() ![]() Drives: 07SedanS06Taco Join Date: Oct 2008
The dealer replaced the rubber seal around the front window under warranty and now I hear other wind noises around the door, rattles in the plastic etc.
![]() Drives: Yaris Hatch Join Date: Aug 2007
Question my 07 did the same thing...
I was told that due to the type of pedal the yaris uses (electronic something or other) that it doesn't close the throttle all the way when "cruising" creating a whistle sound. Does it happen when the pedal is not depressed or also when depressed? I may be completely wrong though |
Ruler of the free world
Drives: 09 Yaris 2D HB Join Date: Jul 2010
Bump.. old thread but that why we search, right?
Anyway, I have a whistle just as discribed in the first post. About 65mph to 85mph. I cant seem to pinpoint it. It does seem to come from the front left area of the windshield. Does not whistle at slower speeds. I rolled the driver window down and I can still hear it so I'm thinking maybe something outside? Does anybody else have this issue? Did anyone above find out what the cause of this was? '09 3-door |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
i have a whistle when driving at 120 km/h. I'm sure its the crosswinds blowing through the windshield wipers.
Update: I have tried taping off items such as wipers, grille emblem, even around the winshield with painters tape with no luck. It is NOT the wipers. I have mostly decided I'm going to have to live with this whistle, as I do not want even more noises as Othater has described.
However, After much wet weather in my area recently, I have noticed it DOES NOT whistle after a good rain. The water is changeing/sealing somthing. This has re-kindled my intrest in getting this fixed. I'm leaning towards an entire winshield replacement. Has anyone else experienced this whistle? Or know of a cure? |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| Displaying Front Plate In CA | hans_fh | California | 42 | 10-22-2008 12:57 AM |
| FS: Extra Set of Fat Cat Front Bumps Stops | Galavoxx | Items for Sale by private party | 1 | 07-03-2007 08:58 PM |
| How can I cover front license plate hole | hans_fh | General Yaris / Vitz Discussion | 13 | 01-03-2007 12:58 PM |
