Old 09-23-2010, 06:13 PM   #1
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
Question About New Tires
Although I am not ready to get new ones yet, I was wondering if 195/60/17 would fit/rub on my 17x7.5 rims?
chrisj is offline   Reply With Quote
Old 09-23-2010, 08:52 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Not familiar with that tyre size. Where did you come up with that?
Old 09-23-2010, 09:13 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
215/50R17 is as big as I think you can go with out any major problems.... but I am with Kimona... I am not familiar with that tire size either
Old 09-23-2010, 09:15 PM   #4
alch3miss
alch3miss's Avatar
Drives: Toyota Yaris
I think theyd fit, but I'd go a little larger.. IMO
alch3miss is offline   Reply With Quote
Old 09-24-2010, 12:04 AM   #5
chrisj
chrisj's Avatar
I saw someone else had 60mm sidewalls, and right now I have 40mm. I have 205/40/17 or something. I guess I should look, huh? I just wanted more sidewall the next time around.
Old 09-24-2010, 12:16 AM   #6
sleey0
Drives: 2008 Yaris LB
Is your ride too rough?
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 09-24-2010, 12:29 AM   #7
chrisj
chrisj's Avatar
Not really, but I would just like more tire between the rim and the road myself. Okay, there's a 205/60 R17.5 that Bridgestone makes. Would that be too much? I guess I need 17-inch tires, not 17.5. I have no idea.
Old 09-24-2010, 12:30 AM   #8
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
tires read...
205mm (wide)/ 40% (of tire width) 17in (rim size)
So for example and 205/40 has a sidewall hight of of just 82mm. (205 x 40% [or 0.4] = 82)
A 195/60 would have a sidewall hight of 117mm and would be WAY too big.
25.4mm = 1in
82mm = 3.23in.
3.23 + 17 (rim size) = 20.23in
117mm = 4.6in
4.6 + 17 = 21.6in.
21.6 - 20.23 = 1.37in.
That's quite a bit taller and you more than likely rub.
This concludes our math lesson for the day.
Old 09-24-2010, 12:36 AM   #9
chrisj
chrisj's Avatar
Okay, thanks BlueVitz. So I would need a 50 profile tire then at the most?
Let me make this way easier. What is the largest tire I can use on a 17x7.5 rim?
I'm afraid my tire n00bness is showing badly. :/
Old 09-24-2010, 12:46 AM   #10
Bluevitz-rs
That works out to a 97.5mm or 4.04in sidewall.
so 20.84 - 20.23 = .61in taller. It might work.
Old 09-24-2010, 10:23 AM   #11
kimona
kimona's Avatar
The tallest tyre you could install with stock suspension is 205/50/17... provided you have proper wheel offset.
Old 09-24-2010, 11:26 PM   #12
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
205/50/17 like kimona said.
just a note:
tires that are meant for 17.5" dia. wheel should NOT be used on a 17" dia. wheel.
Old 09-24-2010, 11:43 PM   #13
Bluevitz-rs
just a note:
Where did you get 17.5" Ø wheel from? It was said on a 17x7.5
Old 09-25-2010, 12:21 AM   #14
chrisj
chrisj's Avatar
I thought the rims I got said 17 x 7.5, but I don't know. Offset was 40. Seems I don't know much.
Old 09-25-2010, 12:29 AM   #15
chrisj
chrisj's Avatar
I'm just going to try to move up to a 50 profile next go round. Thing is, my current tires are new so it will be awhile before I buy anyway.
Old 09-25-2010, 02:37 AM   #16
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
my bad, I got it from your post #7.
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 07:58 PM
Question about tires.. white_rice Canada 10 04-15-2010 02:09 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 08:21 AM
OE wheels + tires question Tonavi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 03-05-2009 11:35 PM
noob question about stock tires xCookiE Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 06-19-2007 09:40 AM
