![]() ![]() Drives: Toyota Vitz Join Date: Sep 2010
IS IT SAFE TO RUN TURBO ON STOCK INJECTORS ?
Dear EXPERTS
ive purchased turbo kit for 1szfe http://www.ninjapower.co.uk/product_...cp10-1szfe-bot the problem is i'm having the stock injectors, link is under http://cgi.ebay.co.uk/Yaris-99-03-1-...b#ht_782wt_911 kindly confirm if running turbo is safe on this setup, and also provide info that how much boost should i run on this setup, as i am installing intercooler as well. Waiting :) |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
no, you'll run lean and burn a piston/valve.
you might be able to run a few pounds...1-2 with no problems, but why add boost if it's only 2lbs? |
but how is it possible that hks has built so expensive kit for this engine without injectors? maybe the fcon controls all ?
once the injectors reach 100% duty or even close, they can't squirt any more fuel. So no, the Fcon cannot change the laws of physics.
Anyone ask you what your air/fuel is, what your boost level is, and if you have gauges for both? Ok - I am.
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Im in a similar situation.
Need to know if.the 1zz injectors will run 12psl.
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats." xbgod - 9/23/2010 |
You need larger injectors after 5 psi.
What is th next step up after 1zz? tC injectors?
![]() ![]() Drives: an egg Join Date: Aug 2010
an upgraded fuel system is a must with any FI
^ what does that mean?
Aside from injectors, I ran the stock fuel system at 8-9 pounds for over eight months. All the supercharger guys are running stock systems, Carlos and Charles both running stock fuel systems with their turbos.
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 10:44 AM |
| What are you doing right now? | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 26819 | 12-31-2010 11:48 AM |
| Can the Yaris handle 6psi with stock ECU, injectors and fuel pump? | trini_per4mance | Forced Induction Forum | 19 | 05-06-2009 02:18 PM |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 01:30 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 03:10 PM |
