Hey guys.
Yesterday I noticed something ackward in my Yaris.When I am choosing 1st/2nd gear, I feel some vibrations from the stick, like it is scratching the inner walls of the transmission.Maybe it needs some oiling.I have manual transmission. I will install my short shifter(when it arrives) to see if the problem comes from the OEM stick.It's pretty annoying!
Any ideas guys?
Sorry I never had that problem... But I did install the Short Shifter at 500 miles
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
before you install the shifter, take it to the dealer. Perhaps something is wrong that they need to fix. If you go in there with a short shifter they will say it caused the problem.
ChinoCharles Intake supporter. |
Yes I am planning to do that.Thanks guys.It is really an unusual problem!
Today the problem is not as intense as yesterday.
Maybe my Yaris wants to persuade me not to be doing street racing!
![]() ![]() ![]() Drives: 07 yaris s sedan Join Date: May 2006
to me it sounds like the cables of the shifter need to be lubed, toyotas use 2 cables to shift gears, when those become dry they can make some weird noises, just take it in to the dealer if you can and show them
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Aug 2006
What causes the shift cable to become dry? And is if difficult to lubricate it yourself?
I did it myself today, before reading your post, and it is ok.
Thanks anyway!
![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
the only thing I've noticed is that it's always somehow hard to engage the 1st gear as long as the car it's not completely immobilized
#11 | |
Once you are moving there really is no reason to go back into first.
Start another Oil Thread!
Then there really is no reason for it. Most of the time you try and shift as seldom as possible.
Well sometimes it is hard to engage 1st gear even if you have less than 5km/h.
#15 | |
There is nothing wrong with the transmission.
Here's a STOP at every street corner. Two choices: completely stop the car and make the rear car going to flash you, or trying to slow the most and then restart - there's the trouble because is hard to restart in the 2nd gear so I had to put it in the 1st while still moving.
Lurker supreme!
if you're rolling slowly, blip the gas with the clutch in, and it will make it easier to put it back in 1st.
2006 Red Blitzed RS 5-door |
Of course I am never doing it, but I what I want to say is that in Yaris, the 1st gear should only be engaged if the car has come to a halt.
| Gas pedal problem? | Befuddled | Performance Modifications | 28 | 01-27-2010 10:55 AM |
| HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 07:00 AM |
| Rear shock absorbers problem | Yaris PTY-507 | Central and South America | 1 | 10-16-2006 05:07 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 10:12 PM |
| no tach= problem for newb? | BrownNBubbly | General Yaris / Vitz Discussion | 19 | 05-18-2006 03:16 PM |
