Old 11-23-2010, 02:02 PM   #1
jstantherprsn
Drives: 01 Toyota Echo
Shocks
Hello Everyone,
I've been looking around for upgrading my shocks. I saw there aren't that many options besides an entire suspension overhaul kit which is like 800 dollars. So far I can only find shocks with sensa drive but they are twin tube. Anyone got any ideas where I can explore other options?
jstantherprsn is offline   Reply With Quote
Old 11-24-2010, 02:21 PM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Are you looking for upgrades or just oem replacements?
Old 11-24-2010, 04:47 PM   #3
yarisdude447
Drives: 2009 Yaris Hatchback
Just want to remind you to make sure to get an alignment after installing the shocks.
yarisdude447 is offline   Reply With Quote
Old 12-06-2010, 11:00 AM   #4
jstantherprsn
just replaced the rear shocks with the nitrogen monroe sensa track. It really stiffened up the back alot. It barely flexs when you press done on the trunk. You almost deform the metal before it it gives, no oscillation at all.
The ride was pretty good but i noticed that the fronts need a little help. On cement highway at like 65 all the bumps in the road from the 100 strips were causing a bouncing in the front which stopped by the time it reached the back.
Handling improved a little with the rear shocks. I'm debating the rear sway bar now.
Old 12-09-2010, 12:19 PM   #5
2005rs
Drives: 2005 Echo Rs
anyone have thoughts on kyb vs monroe shocks?
I've gotten some apex springs (lowering 32mm) that I want to install along with new shocks in the spring. should I go ahead and get camber bolts now or wait until I get the alignment to see if I need them?
2005rs is offline   Reply With Quote
Old 12-09-2010, 01:51 PM   #6
jstantherprsn
I error on the caution of getting them now.
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 02:49 PM
Tein S-tech over Stock shocks daddz07 General Yaris / Vitz Discussion 0 08-10-2010 11:48 AM
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 04:45 PM
OEM/stock shocks and springs fmicle Items for Sale by private party 3 03-23-2010 03:02 AM
front shocks independent from rear shocks? ammophobia Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-05-2010 12:34 AM
