![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
what is behind the instrument panel
maybe somebody have picture of dismantling the instrument panel since I need to see whether the heating which is going on the windshield is accessible when I dismantle the instrument panel ?
I am asking because now when the temperature dropped below zero the heating went is rattling :( thanks |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
If you remove the cluster, the center vent duct is under it. Once you remove that (it just snaps into place), you have a nice view into the top of the airbox. In this picture the top of the dash is removed, so you can see more than you will see with just the cluster removed:
great
thanks scott |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
How much room is there between the vents and the piece right in front of the IP?
(If I wanted to install something in or under that panel right in front). |
Thread Tools | |
Display Modes | |
DIY rear Interior panel removal 09 3dr LB | bkndacn | Cosmetic Modifications (Exterior/Interior) | 10 | 03-11-2013 01:05 AM |
Instrument Panel Light out? | ApolloX | DIY / Maintenance / Service | 2 | 09-28-2010 05:56 PM |
Instrument Panel goes out if I turn on my lights | ceceb | DIY / Maintenance / Service | 9 | 07-08-2010 05:56 PM |
Question about replacing Instrument Panel!! | Wowzers78 | General Yaris / Vitz Discussion | 0 | 03-18-2010 09:25 AM |
New instrument panel | fmicle | DIY / Maintenance / Service | 17 | 07-19-2009 09:09 PM |
